System crashing and rebooting at random
raginkajan
It started about 2-3 weeks ago, it will reboot at random...whether I am playing a game or just browsing the web...not sure how to proceed.
I had the latest drivers for my GPU, and I tried rolling back but it did not help at all.
here are my specs:
  • i7 3770k
  • gigabyte gtx 660ti
  • 8gb ram
  • as rock z77 extreme 4
  • thermaltake tr600w psu
    intel i7 3770k
    asus z77 extreme 4
    8gb
    gigabyte gtx 660ti
    chrome
    windows defender
usasma
Mr. Cranky Pants
This device needs it's drivers installed:
Not Available ACPI\INT33A0\0 The drivers for this device are not installed.
It is most likely your Intel(R) Smart Connect Technology Device - download it from the PC manufacturer's website and install it.
Daemon Tools (and Alcohol % software) are known to cause BSOD's on some Windows systems (mostly due to the sptd.sys driver, although I have seen dtsoftbus01.sys blamed on several occasions).
Please un-install the program, then use the following free tool to ensure that the troublesome sptd.sys driver is removed from your system (pick the 32 or 64 bit system depending on your system's configuration): [DEL] DuplexSecure - FAQ [/DEL] Link broken as of 21 Jul 2012
New link (15 Aug 2012): DuplexSecure - Downloads (pick the appropriate version for your system and select "Un-install" when you run it).
Alternate link: Disc-Tools.com
Manual procedure here: Registry and SPTD problems | DAEMON Pro Help
MBfilt64.sys Thu Jul 30 23:40:32 2009 (4A7267B0)
Realtek HiDefinition Audio driver (file labelled as Creative Audio Driver)
http://www.carrona.org/drivers/driver.php?id=MBfilt64.sys
PxHlpa64.sys Mon Oct 17 10:29:34 2011 (4E9C3BCE)
Sonic CD/DVD driver (used by many different CD/DVD programs)
http://www.carrona.org/drivers/driver.php?id=PxHlpa64.sys
k57nd60a.sys Wed Oct 19 16:17:36 2011 (4E9F3060)
Broadcom NetLink Gigabit Ethernet NDIS6.x Unified Driver
http://www.carrona.org/drivers/driver.php?id=k57nd60a.sys
If the BSOD's continue after the above steps, then follow these suggestions for troubleshooting the STOP 0x116 error: Video TDR Timeout - 0x116 + 0x117 - Sysnative Forums
Analysis:
[FONT=lucida console]**************************Sun Mar 24 09:48:53.210 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\032413-21718-01.dmp]
Windows 8 Kernel Version 9200 MP (8 procs) Free x64
Built by: [B]9200[/B].16496.amd64fre.win8_gdr.130108-1504
System Uptime:[B]5 days 16:03:38.407[/B]
*** WARNING: Unable to verify timestamp for nvlddmkm.sys
*** ERROR: Module load completed but symbols could not be loaded for nvlddmkm.sys
Probably caused by :[B]nvlddmkm.sys ( nvlddmkm+9336ac )[/B]
BugCheck [B]116, {fffffa80203a13e0, fffff88004fe46ac, ffffffffc000009a, 4}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#Example"]VIDEO_TDR_FAILURE (116)[/URL]
Arguments:
Arg1: fffffa80203a13e0, Optional pointer to internal TDR recovery context (TDR_RECOVERY_CONTEXT).
Arg2: fffff88004fe46ac, The pointer into responsible device driver module (e.g. owner tag).
Arg3: ffffffffc000009a, Optional error code (NTSTATUS) of the last failed operation.
Arg4: 0000000000000004, Optional internal context dependent data.
BUGCHECK_STR:  0x116
DEFAULT_BUCKET_ID:  GRAPHICS_DRIVER_TDR_FAULT
PROCESS_NAME:  System
FAILURE_BUCKET_ID: [B]0x116_IMAGE_nvlddmkm.sys[/B]
CPUID:        "Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz"
MaxSpeed:     3500
CurrentSpeed: [B]3500[/B]
  BIOS Version                  P2.50
  BIOS Release Date             10/31/2012
  Manufacturer                  To Be Filled By O.E.M.
  Product Name                  To Be Filled By O.E.M.
[/FONT]
3rd Party Drivers:
[COLOR=RED][B]MBfilt64.sys                Thu Jul 30 23:40:32 2009 (4A7267B0)[/B][/COLOR]
[COLOR=RED][B]PxHlpa64.sys                Mon Oct 17 10:29:34 2011 (4E9C3BCE)[/B][/COLOR]
[COLOR=RED][B]k57nd60a.sys                Wed Oct 19 16:17:36 2011 (4E9F3060)[/B][/COLOR]
[COLOR=RED][B]aedsatxg.SYS                Tue Dec 27 17:30:45 2011 (4EFA4715)[/B][/COLOR]
[COLOR=RED][B]dtsoftbus01.sys             Fri Jan 13 08:45:46 2012 (4F10358A)[/B][/COLOR]
GEARAspiWDM.sys             Thu May  3 15:56:17 2012 (4FA2E2E1)
RTKVHD64.sys                Tue Jun 19 04:50:56 2012 (4FE03D70)
IntcDAud.sys                Tue Jun 19 10:40:51 2012 (4FE08F73)
hiber_storahci.sys          Wed Jul 25 22:30:35 2012 (5010ABCB)
dump_storahci.sys           Wed Jul 25 22:30:35 2012 (5010ABCB)
[COLOR=RED][B]sptd.sys                    Sat Aug 18 17:05:38 2012 (503003A2)[/B][/COLOR]
iaStorA.sys                 Sat Sep  1 21:01:24 2012 (5042AFE4)
RzSynapse.sys               Thu Oct 18 05:04:42 2012 (507FC62A)
igdkmd64.sys                Wed Dec 12 19:42:26 2012 (50C92472)
HECIx64.sys                 Mon Dec 17 14:32:21 2012 (50CF7345)
nvhda64v.sys                Wed Dec 19 00:41:41 2012 (50D15395)
nvlddmkm.sys                Thu Mar 14 03:29:32 2013 (51417C5C)
[/FONT]
http://www.carrona.org/drivers/driver.php?id=dtsoftbus01.sys
http://www.carrona.org/drivers/driver.php?id=GEARAspiWDM.sys
http://www.carrona.org/drivers/driver.php?id=IntcDAud.sys
http://www.carrona.org/drivers/driver.php?id=hiber_storahci.sys
http://www.carrona.org/drivers/driver.php?id=dump_storahci.sys
http://www.carrona.org/drivers/driver.php?id=sptd.sys
http://www.carrona.org/drivers/driver.php?id=RzSynapse.sys
http://www.carrona.org/drivers/driver.php?id=igdkmd64.sys
http://www.carrona.org/drivers/driver.php?id=nvhda64v.sys
    Win8.1Pro - Finally!!!
    Samsung/NP780
    upgraded to 12 gB from 8 gB
    800x600
    no Mouse - Trackball!!!!
raginkajan
thanks for your response,
I have updated the drivers and unchecked the Automatic Restart in Control Panel but I still crash and there is still no BSoD
    intel i7 3770k
    asus z77 extreme 4
    8gb
    gigabyte gtx 660ti
    chrome
    windows defender
