switch for running an application as administrator?
zivshosh
Greetings
Is there a switch for running an application as an administrator like: regedit /a or regedit /admin?
thanks
    DELL
    I5
    4GB
    Intel
    Firefox, Chrome, Internet Explorer
this I already know but it doesn't allow me to run something like sfc /scannow
running from context menu as administrator allow only running sfc which does nothing (opens cmd and closes it without scanning)
    DELL
    I5
    4GB
    Intel
Open task manage. File/Run new task and then tick to run as administrator.
Option Eight above.
    windows
    alienware
As a workaround, you could create a .bat file to run sfc /scannow or whatever, create a shortcut of the .bat file, set the shortcut to "Run as administrator" using Option Six, then have the context menu run the shortcut.
it worked! the batch file. again I have to run notepad as administrator. I still don't know why I get the 0x000007b error message window.
thanks
    DELL
    I5
    4GB
    Intel
It's most likely from something you may have done while taking ownership of your C:\Windows folder. :(
