Surface Pro
kb7uar
Kingman az.
45
Is their a cd/dvd player writer that will work on a Microsoft Surface Pro with a USB connection?, If their is, will it also let you write to it?
    Hp pavilion dv7
    4 gigs
    built in
    wireless
    15 megs
24,021
    3 x 27" Asus VE278Q
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
I bought a Samsung SE-218/RSBS external USB DVD burner that works perfectly with my Surface Pro 1. Dual Layer, and came with Nero, which works fine for common uses. It's also capable of running in AV Mode, which allows reading data dvd's with android devices, and playing MPG video off data dvd's when plugged into a media capable USB on a newer TV.
    windows 8.1 pro
    Tablet
    Microsoft Surface Pro 1
    Intel I5
    4 gb
    Intel
    Cheap Bluetooth 5 button
    IE 11
strollin
Old Guys Rule!
N. Calif
4,689
There are "Ultra-portable" drives that will work but not all will. One possible gotcha is that the USB port on the Surface may not be able to supply enough power for the external drive. If you use a Y-cable with the DVD drive you can plug the power part of the Y into the USB port on the Surface's AC charger. You could also use an external drive that has it's own power supply.
    W10 Pro (desktop), W10 (laptop), W10 Pro (tablet), W10 (laptop)
    Home built i7-8700K, Toshiba Satellite S55-A Laptop, MS Surface Pro 3, Dell Inspiron 15 5000
    3.7Ghz Core i7-8700K, 2.4Ghz Core i7-3630QM, 1.9Ghz Core i5 4300U, 2.8Ghz Core i5 6200U
    ASUS TUF Z370-Pro Gaming, Toshiba, MS, Dell
    16G, 12G, 4G, 8G
    Nvidia GTX 1050, Intel HD Graphics 4000
    ATI High Definition Audio (Built-in to mobo)
    Dell S2817Q 28", 15.6"
    3840x2160, 1366x768 (laptop)
    500GB ssd boot drive with 2 & 10TB Data on Desktop, 512GB ssd for laptop, 128GB SSD tablet, 500GB ssd laptop
    Corsair CX 750M
    Antec 100
    Coolermaster CM 212+
    IBM Model M - used continuously since 1986
    Microsoft IntelliMouse
    120Mbps/6Mbps down/up
    FireFox
    MSE on desktop, Defender on laptop
    Retired after working in the tech industry for 41 years. First 10 years as a Technician, the rest as a programmer/software engineer. After 1 year of retirement, I was bored so went back to work as a Robotic Process Automation Consultant.
The Samsung SE-218/RSBS is an 'ultraportable' that runs fine on a single USB2 cable. The Surface Pro 1 has more than enough power in it's USB3 port to reliably run it. I would suggest an inexpensive powered USB3 hub, though, makes it nice to attach multiple devices.
    windows 8.1 pro
    Tablet
    Intel I5
    4 gb
    Intel
    IE 11
