I installed Windows 8.1 earlier and had this (apparently common) watermark error on the desktop about SecureBoot having a problem.
I went into my BIOS, made sure it was enabled, and then set up some kind of "key" that the directions said to do. I clicked save and exit, and after that instead of booting into Windows, I'd be at a black screen, everything running inside my computer, and with my keyboard and mouse both turning on at the same time, then turning off at the exact same time 3-4 seconds later along with a quiet sort of clicking sound inside the computer. Over and over, looping endlessly.
I opened it up, checked connections, removed parts and tried booting with each thing moved. It only finally booted when I removed my graphics card and plugged my monitor into the onboard DVI port.
After that I shut down, put my graphics card back in, booted with the monitor still plugged into the onboard DVI, and it booted without issue. I then plugged the monitor back into the graphics card DVI port and rebooted. Went back to the clickly flashy no-POST cycle. After repeating this whole process a few times, I realized that when it's in that cycle, if I just plug the monitor into the onboard DVI port, I get the POST beep and everything boots up.
Eventually I just did some messing around in the BIOS, turned SecureBoot off as well as disabled onboard graphics and then booted the PC back up with the monitor in the graphics card DVI port. It boots fine now, I've rebooted 5-6 times now and it goes into Windows 8.1 no problem.
Does anyone have ANY idea of what might have caused this? I'm afraid it's going to come back.
