Sound Worked in Consumer Preview but not Release Preview
carstorm
Hrrisonburg
22
My sound used to work in the consumer preview fine but since I upgraded to the Release Preview I need the volume max and headphones in to hear anything. Any help appreciated. If more info is needed just ask.
    Windows 8 Pro x64
    AMD Radeon
    680 GB Internal
    1TB External
    56MBPS
brummyfan
Birmingham
1,487
Check in your Device Manager whether you have this driver,
    Win 8.1
    Acer Aspire E1-571
    i5-3230m
    Acer Type-2
    8GB DDR3 1333MHz
    Intel HD 4000
    High Definiton Audio Device
    Generic
    1366x768
    Samsung 850 Pro 256GB
    Generic
    QWERTY
    ELANTECH Touchpad
    12.68Mbps
    IE11
brummyfan
Birmingham
1,487
    Win 8.1
    Acer Aspire E1-571
    i5-3230m
    Acer Type-2
    8GB DDR3 1333MHz
    Intel HD 4000
    Generic
    1366x768
    Generic
    QWERTY
    ELANTECH Touchpad
    12.68Mbps
    IE11
carstorm
Hrrisonburg
22
I did that and the cmd prompt said:
Windows Resource protection did not find any integrity violations.
    Windows 8 Pro x64
    AMD Radeon
    680 GB Internal
    1TB External
    56MBPS
brummyfan
Birmingham
1,487
Then look for the drivers from manufacturers and if that doesn't work, a clean install might solve the problem.
    Win 8.1
    Acer Aspire E1-571
    i5-3230m
    Acer Type-2
    8GB DDR3 1333MHz
    Intel HD 4000
    Generic
    1366x768
    Generic
    QWERTY
    ELANTECH Touchpad
    12.68Mbps
    IE11
brummyfan
Birmingham
1,487
#8
    Win 8.1
    Acer Aspire E1-571
    i5-3230m
    Acer Type-2
    8GB DDR3 1333MHz
    Intel HD 4000
    Generic
    1366x768
    Generic
    QWERTY
    ELANTECH Touchpad
    12.68Mbps
    IE11
carstorm
Hrrisonburg
22
#9
That said ever one was Microsoft but I know their not. After look around I found "SRS Premium Sound" engraved my my pc. I do a search and found out its by relteck like many other parts of my system. However I can't find the windows 8 driver for it now. I'll keep searching but if anyone comes across a download please post it. TY
    Windows 8 Pro x64
    AMD Radeon
    680 GB Internal
    1TB External
    56MBPS
brummyfan
Birmingham
1,487
#10
Try the driver for window 7 from here and let us know whether it helps.
Realtek Definition Audio Codecs
    Win 8.1
    Acer Aspire E1-571
    i5-3230m
    Acer Type-2
    8GB DDR3 1333MHz
    Intel HD 4000
    Generic
    1366x768
    Generic
    QWERTY
    ELANTECH Touchpad
    12.68Mbps
    IE11
Pancool
England
44
#13
I didn't notice that bit when I looked through it but I can't see why it wouldn't if it worked in consumer preview unless you had the of the website for it for windows 7 installed.
In fact I have noticed alot better compatibility with the stuff I use on release preview than on consumer preview.
    Windows 8 release preview
carstorm
Hrrisonburg
22
#14
On the consumer preview I didn't have to change anything it worked fine from the start. Now it only works when I have headphones in.
    Windows 8 Pro x64
    AMD Radeon
    680 GB Internal
    1TB External
    56MBPS
brummyfan
Birmingham
1,487
#15
Hi carstorm, did you do a upgrade install or a clean install?
    Win 8.1
    Acer Aspire E1-571
    i5-3230m
    Acer Type-2
    8GB DDR3 1333MHz
    Intel HD 4000
    Generic
    1366x768
    Generic
    QWERTY
    ELANTECH Touchpad
    12.68Mbps
    IE11
carstorm
Hrrisonburg
22
#16
Clean Install. There is no way to upgrade from the consumer preview to the release Preview.
    Windows 8 Pro x64
    AMD Radeon
    680 GB Internal
    1TB External
    56MBPS
brummyfan
Birmingham
1,487
#17
    Win 8.1
    Acer Aspire E1-571
    i5-3230m
    Acer Type-2
    8GB DDR3 1333MHz
    Intel HD 4000
    Generic
    1366x768
    Generic
    QWERTY
    ELANTECH Touchpad
    12.68Mbps
    IE11
carstorm
Hrrisonburg
22
#18
    Windows 8 Pro x64
    AMD Radeon
    680 GB Internal
    1TB External
    56MBPS
brummyfan
Birmingham
1,487
#19
    Win 8.1
    Acer Aspire E1-571
    i5-3230m
    Acer Type-2
    8GB DDR3 1333MHz
    Intel HD 4000
    Generic
    1366x768
    Generic
    QWERTY
    ELANTECH Touchpad
    12.68Mbps
    IE11
carstorm
Hrrisonburg
22
#20
    Windows 8 Pro x64
    AMD Radeon
    680 GB Internal
    1TB External
    56MBPS
