Solved Side by Side configuration error
reddace
13
I have two operatings systems. Windows 7 on one drive and Windows 8 on the other. I have a program called PowerDirector 11 installed on the Windows 7 drive. I went to install the said program on the Windows 8 drive, (to be able to access it from either drive) and when I try to open or run the .exe, I get the error "The application has failed to start because the side-by-side configuration is incorrect. Please see the application event log for more details." Not much information in the application event log. Don't know if anyone else has had this problem with Windows 8? Thanks in advance for any kind of help or suggestions.
    Windows 7
archer
India
1,034
    Windows 7 x64/ Windows 8.1 x64
    Self Made
    Intel i5 2500K @ 3.3GHz
    Asus Z68 V Pro
    16GB DDR 3
    HIS 6870 ICEq edition
    Samsung 22" Display
    WD 1 TB
    Seagate 2 TB
    WD 320 GB
    coolermaster 750 W
    Coolermaster HAF 912
    TVS Gold
    Samsumg
    4 Mbps
    AVG 2013 IS
XweAponX
That's a great collection of all of those Visual C++ packages, all in one place. When I get that error it's usually associated with the 2005 package.
    AMD 4400+/4200+
    2 GB/3GB
    GeForce 8400 GS/GeForce 210
    Hitachi 40" LCD HDTV
    "1842 x 1036"
    WD My Book 1140 USB Device
    Works 550w
    MSI "M-Box"
    Water Cooled
    Dell Keyboard
    Microsoft Intellimouse
    Cable Medium Speed
    Chrome/IE 10
    Eset NOD32 6.x/Win Defend
token824
1
Hi! My pc just automatically updated and when I logged in this error came out. My os is windows 8. Please help me solve the problem. I just dont know where to start. How did you solve yours?
