JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser .
Solved Program not running at startup
Hello, I use chill control V, for my cooler. I have is set to run at startup. It shows in task manager start up tab, but it never starts by itself. Am I missing something simple?
25 KB
12.5 KB
OS
W10 Pro X64
Dude
Intel(R) Core(TM) i5-3570K CPU OC@ 4.5 GHZ Turbo
MSI Z77MA-G45 (MS-7759)
8.00 GB DDR3 1600Mhz
PNY GTX 760
Realtek High Definition
Dell S23O9W, HP L1710
DELL-1920 x 1080 HP-1280 x1024
Crucial m4 256 SSD WD 7200RPM 500GB
Seasonic X650 Gold
Zalman Z12
Antec Kuhler 920
Logitech
MSI DS100 Interceptor
50 down 5 up
Chrome, IE 11
Logitech X-620 Speakers
Missing my GIF avatars:(
Maybe it's delayed startup?
All my "Not Measured" start a few seconds to a minute
after my desktop appears. Is this what you mean?
OS
Cliff's Black & Blue Wonder
Intel Core i9-9900K
ASUS ROG Maximus X Hero
hanteks Enthoo Pro TG
Trust GTX THURA
Trust GTX 148
25+/5+ (+usually faster)
Edge; Chrome; IE11
Router: FRITZ!Box 7590 AX V2
I thought that at first, but I rebooted and ? minutes later it still did not start. I will restart now and see if waiting a while works.
OS
W10 Pro X64
Dude
PNY GTX 760
Seasonic X650 Gold
Zalman Z12
Antec Kuhler 920
Logitech
50 down 5 up
Chrome, IE 11
OS
Intel Core i9-9900K
Trust GTX THURA
Trust GTX 148
Edge; Chrome; IE11
Well making progress, it popped up a UAC at startup to allow it. I have it set to run as administrator.
OS
W10 Pro X64
Dude
PNY GTX 760
Seasonic X650 Gold
Zalman Z12
Antec Kuhler 920
Logitech
50 down 5 up
Chrome, IE 11
If you have problem making it run at startup, talk to MilesAhead.
OS
Intel Core i9-9900K
Trust GTX THURA
Trust GTX 148
Edge; Chrome; IE11
OS
W10 Pro X64
Dude
PNY GTX 760
Seasonic X650 Gold
Zalman Z12
Antec Kuhler 920
Logitech
50 down 5 up
Chrome, IE 11
OS
Intel Core i9-9900K
Trust GTX THURA
Trust GTX 148
Edge; Chrome; IE11
Turns out turning off run as administrator fixes it
. Forgot about UAC and startup
OS
W10 Pro X64
Dude
PNY GTX 760
Seasonic X650 Gold
Zalman Z12
Antec Kuhler 920
Logitech
50 down 5 up
Chrome, IE 11
Glad you got it sorted out. Sometimes just asking a question or talking about something helps one to see it from another angle.
OS
Intel Core i9-9900K
Trust GTX THURA
Trust GTX 148
Edge; Chrome; IE11
Or runs one in circles. I started to create a task in task scheduler, then It finally dawned on me. It doesn't need to run as administrator.
Thanks for your help Cliff, have to spread some + first
OS
W10 Pro X64
Dude
PNY GTX 760
Seasonic X650 Gold
Zalman Z12
Antec Kuhler 920
Logitech
50 down 5 up
Chrome, IE 11
Don't we all!
OS
Intel Core i9-9900K
Trust GTX THURA
Trust GTX 148
Edge; Chrome; IE11
I think that only the program is marked as "High" can it run as the computer starts
Wait for some minutes to see if it change.
Or if you have set it to delay start?
OS
Windows 8.1 Pro 64-bit, Windows 10 64-bit
