Solved Problems setting folder view option
pancake
7
When I change the view option of a folder; IE List to Details etc; it changes for all the folders. I'd like to be able to just change the view for that single folder. It's really annoying having to reset the view with every new folder I decide to open.
    8/XP
23,744
Hello pancake,
It sounds like you are doing this in a library instead of a folder. All included folders in a library share the same folder view setting no matter which folder in the library it was set in.
To have separate folder views, you would need to be in the actual folder instead of in the library.
For example, instead of the Documents library, you would want to be in your actual "C:\Users\(user-name)\Documents" folder.
Hope this helps, :)
    3 x 27" Asus VE278Q
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
23,744
You're most welcome. :)
    3 x 27" Asus VE278Q
    Logitech MX Master
    Lumia 1520 phone
