Problem With Store
mygamers
Tehran
Hi guys
I have a problem with store
when i open the store
it show me
Your PC isn`t connected to Internet or Windows store isn`t Availble right now to use the store connect to the Internet and try again
but my system is connect to net and i work with internet
somebody can help me
or a way to fix this error
sorry for my bad English
You should be able to access and browse the store even when logged on with a local account, however, if you want to download/install any of the applications, you'll need to sign in with a Microsoft account. There is also a chance that the message you're seeing suggests you can 'try again' as part of the message. if this is so, it's a transient network problem, which if you keep trying, will eventually let you connect.
If, after continued attempts to gain access, with or without a Microsoft account, considering the other problems you've bee having - Problem With Mail,People,Messaging - I'd suggest you consider a Refresh
I do that but nothing has been change
Store steel doesnt work
mail , people , messaging too
Unfortunately, you haven't replied to the other thread, with the information I requested, so it's difficult to suggest anything other than the a refresh. The tutorial is in the link above.
Perhaps it is something to do with geography and Microsoft not having a "Store" there (yet)? I have no clue and its just a guess at a possible reason.
Possibly true but as the OP has a Microsoft account and thus a Windows ID, he's obviously been able to connect to some services in the past. However, until the OP can post some additional details, anything is speculation.
Indeed, Iran is not of the list of countries for 'Store' access and Microsoft's geopolitical statement would suggest this is unlikely to change. There's also the question of censorship within the country itself. However, the OP has also had problems accessing Mail, People and Messaging yet, the OP does have a Microsoft account. Regardless, the OP sent me a PM with an update and I've asked for additional information.
Hi Guys,
I can open the store, but whenever i install any free apps, it prompts as
I've network connection and I can open any web pages in IE.
Please help me...
Try setting I.E. to use Tor with Polipo.
I personally use Tor with Privoxy though.
Either is good.
Hi Gman,
I wanted to use Tor from long back itself, as I'm using wireless network from college.
But Tor hangs at "Establishing an encrypted directory connectionTor.png"
Close Vidalia (that also closes Tor).
Delete everything in C:\Users\{yourusernamehere}\AppData\Roaming\tor
Then extract the contents of my attachment to that folder. Start Vidalia.
Works? If not, your ISP might be blocking the heck out of it to where the files I've given you can't even work.
Make sure your time and date are set right, or it won't work if that's wrong either.
Ya Gman..
ISP is blocking though... Same problem...
Can't do anything...:(
Anyway Thanks for reply..
Go to your Network tab in Vidalia and try checking the boxes there for these 3. Try different combinations if needed. Close/restart after each try.
