Problem with my new WiFI Adapter
Hi all!! I am new here... Today I bought the intel centrino advance N6235 wireless card for my laptop. I have installed all drivers from intel, but only bluetooth works. Wifi doesn't recognized from the system, like i have no wifi adapter connected. What i can do??
Thanks for your answers.
    Windows 8 Pro 64-bit
    Toshiba Satellite L750-1NJ
    Intel Core i7-2670GM
    Intel Sandy Bridge
    8GB DDR3 1333Mhz
    Nvidia GeForce GT525M
    15,6"
    1366x768
    750GB 7200rpm
    8Mbps
jimbo45
Hafnarfjörður IS
4,373
Hi there
doesn't the laptop have a built in wireless card -- sometimes they don't have LAN ports but I'm sure any laptop (inc cheap netbooks) have had wireless cards already FOR AGES as standard -- at least 10 - 12 years -- just ensure it's enabled.
Cheers
jimbo
    1 X LG 40 inch TV
    2 X 3 TB sata
    5 X 1 TB sata
    0.12 GB/s (120Mb/s)
I'm sure the Op just wanted to upgrade the internal NIC to improve performance as this NIC has 300Mbps and dual band capability.
Unfortunately people who install this NIC are having the same problem getting the wireless to work with Windows 8, the Bluetooth is working but not the wireless, it's most likely a driver problem but I'll look around for a solution.
The problem could be with the Intel Pro set connection utility "connection software' which isn't required and tends to can sometimes cause problems but the latest drivers from Intel should work.
Cannot identify wifi intel centrino advanced-n 6235 in windows 8
I would think the Intel site would have the latest drivers for this. Try the latest ones dated 7-23-13.
It may work best to uninstall the old drivers beforehand. :)
https://downloadcenter.intel.com/Se...oductProduct=Intel®+Centrino®+Advanced-N+6235
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    8GB Gskill DDR2 1200Mhz
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take 1000watts
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
Hi! Yes I [FONT=verdana, Tahoma, Calibri, Verdana, Geneva, sans-serif]bougth this network card to have full HD streaming with 300mbps speed, dual band and bluetooth 4.0 technology.[/FONT] I have downloaded and installed this drivers you say, today, dated 7-23-13 but doesn't work. But on intel's site says that is compatible with windows 8. Please help me!!
    Intel Sandy Bridge
    8GB DDR3 1333Mhz
    15,6"
    1366x768
    750GB 7200rpm
    8Mbps
I've got the opposite issue with the Intel Centrino Advanced-N 6230 a/b/g/n WiFi + Bluetooth 3.0 Wireless N Combo Card. My Wi-Fi works great, but I'm not seeing any Bluetooth options under Settings>Change PC Settings>PC and devices or Settings>Change PC Settings>Network. My BIOS is on the latest F.29 version (there are no additional settings for bluetooth there). I checked the device manager and no missing driver appears; there's absolutely no mention of bluetooth there either. Can anyone help shed some light on this?
    Windows 8.1 Pro x64 with Media Center
    HP Pavilion m7-1015dx
    Intel Core i7-3610QM
    Hewlett-Packard 181C 52.24
    16GB Corsair Vengence DDR3 PC3-12800 (1600MHz) SDRAM
    Intel HD Graphics 4000
    1600x900
    Corsair Force 3, 120GB SATA Solid State Drive (boot drive)
    Seagate 1TB SATA 5400rpm HDD (internal storage drive)
    144 Mbps
    Chrome Beta
alphanumeric
slightly off center
Gold Member
Some manufacturers incorporate a white list in their BIOS. IF your replacement part is not on the white list the BIOS will not initialize it or use it. I don't know if this is your problem, just want you to be aware of it. I updated the WIFI card in my ASUS laptop to a dual band card. I uninstalled the old adapter in device manger and checked the delete drivers option. Then swapped cards and let Windows install the newest drivers for the new card.
    Windows 10 Education 64 Bit
    Asus
    Thermaltake TR 620
    Stock heatsink fan
    Logitech Wireless K350 Wave
    80 Mbps Down 30 Mbps Up
Thanks for the response. I believe this card is approved for the board. I'd done some research before purchasing it. I will, however, try uninstalling and swapping the cards again. Thanks.
    1600x900
    144 Mbps
    Chrome Beta
