KhushBohra
Pls help me....I have never felt this much helpless anytime before.,,,,now it is feeling like even internet can't help me and I wish this to be wrong..so pls help..I am fed up now..
First let me give you all a brief history..
I am working in a MNC where they have installed McAfee which is really the *******...it is blocking almost everything....from everything I meant EVERYTHING really it's annoying..
My organisation has encrypted the whole drive...they have whole control on my settings....but I know everything can be changed through registry, group policy editor, etc
Now moving to my problems one by one
1.) Creating hotspot from office wifi
My office wifi is not password protected..it is more than that...it is like some EAP authentication PEAP...which i think is impossible to access in mobile because it requires some certificates I suppose..
So I thought the other way round by creating a hotspot on my laptop......and this is the real problem...
As every setting is against any sharing from my laptop....so I started changing those settings
First of all edited registry settings regarding sharing i.e shown in below screenshot
Than gpedit.msc
Than enabled ICS and Routing and Remote Services in services.msc
And than gave following commands [beacuse Connectify doesn't work]
netsh wlan set hostednetwork mode=allow ssid=My key=abcde12345
netsh wlan start hostednetwork
And enabled "Allow other network users to connect through this......." and selected Local Area Connection *12
So I think all the steps are correct
but than the main problem started........
It is just not even showing SSID in my mobile....I am not able to figure out...
Once I thought it is not possible to share Wi-Fi connection over wifi hotspot so I accessed internet through a lan connection in office and much to my surprise it worked...whoaaaa...it worked and I can use it in my mobile....
But not at every place or floor there is ethernet port...so I wish to start hotspot through wifi instead...Pls solve this and one thing I can tell is that as soon as I disconnect the wifi network or I can say I am not connected to any wifi connection in office but still wifi is on than i can see SSID in my mobile...I don't know why it is so but yes it is like this only....
So pls guys figure it out
One more very big problem is that I am even not able to create hotspot through my dongle..and the problem in dongle is that..SSID is showing in mobile and it is able to connect it too but there is no internet access...I have tried all things like "Allow other network users to connect through this......." is enabled or not.......i don't know why it is not working now as it was previously working before I got my laptop formatted...
So guys pls pls pls solve this..I am in need of internet in my mobile..
2.) Second problem is regarding blocked sites or softwares
I know I can use proxy sites but they too are blocked and so I am at present a software named Ultrasurf but actually I wanna know that is there no real solution to all these problems..
Can;t I just go to registry or whatever and disable McAfee services so that all blocked sites again starts working...McAfee is so powerful that I am just feel like throwing laptop....
Pls help guys...
Than gpedit.msc
Pls help guys...
