LegitCamel
I just built my PC and this is the first time ive ever built a PC and everything works fine except that my PC isnt recognizing my graphics card, i go into device manager and look at my display adapters and it only show the regular windows one. I currently have my HDMI cable plugged into the graphics card and can see everything on the monitor fine, im actually using the pc right now to type this. yesterday i had an issue with the power supply i was using so i got a stronger one, but was using the pc without the graphics card for awhile just to install some programs i knew i would be using once i got this all figured out. heres the full build.
Processor:
AMD FX-6300 Vishera 6-Core 3.5 GHz (4.1 GHz Turbo) Socket AM3+ 95W FD6300WMHKBOX Desktop Processor
Motherboard:
MSI 760GMA-P34 (FX) AM3+ AMD 760G SATA 6Gb/s USB 3.0 Micro ATX AMD Motherboard
PowerSupply:
CORSAIR CXM series CX750M 750W 80 PLUS BRONZE Certified Modular Active PFC
Graphics Card:
SAPPHIRE NITRO Radeon R9 380 DirectX 12 100384NT4GOC-2L 4GB 256-Bit GDDR5 PCI Express 3.0 x16 HDCP Ready Dual-X OC Version w/ backplate (UEFI) Video Card
I also took some parts out of an old PC I took 8 gb of ram, a cd drive and a 1 tb hard drive. I didnt clear the harddrive completely because i wanted to keep windows 8 on it so i didnt have to buy a new copy, not sure if some of the old pc settings are screwing with it or not. but everything else on it is working great.
Processor:
Motherboard:
PowerSupply:
Graphics Card:
