Network Adapters slow speed on restart.
buseng
I have suddenly had a strange problem occur. Everytime I restart my Windows 8.1 desktop my internet connection speed drops from it's normal 50Meg to around 3Meg when running any speedtest programme. The only way to cure this is to uninstall & re-install my network adapters through device manager. All is ok then until my next reboot & then it all happens again. It is the same on both the Ethernet connection & the wireless adapter. I have tried re-installing drivers etc to no avail. Something strange about my network setup. I have also ran various virus scans but nothing showed up.
This suddenly started last Saturday & I cannot see what could of caused it, haven't installed any new programmes or anything.
Any clues please as it is a nuisance keep reinstalling my network adapters every time I reboot.?
All my other devices are ok including a Windows 8.1 laptop.
    Windows8 Pro
If it is with both. Then we need to look at what is the manufacturer & model of the router. Also make sure that you are not using the Microsoft signed drivers, but the Manufacturer's or chipset drivers.
    Linux Mint 17.2
    12GB
    AMD Radeon™ HD 7310 Graphics
    Realtek HD
    LCD
    1366 x 768
    Crucial M500 240GB SSD
    Logitech M525
    45/6 - ATT U-Verse
    None needed. It is Linux.
Thanks for the reply, however I have by-passed the router (a Technicolor TG582N) & plugged the Ethernet cable direct into a separate modem creating a connection through Windows. The same thing happens which must rule out the router. Also now noticed the same thing happens if you unplug the Ethernet cable from the router & plug it into another device like a modem or even back into the router without re-booting the pc.
The drivers are genuine manufacturer ones & been updated all to no avail.
As I think I said it only happens on my Win 8.1 desktop, all other devices including a Win 8.1 laptop are ok & don't suffer with this. It just happened without warning last weekend & I cannot think of anything I have done like installing any new programmes.
It only happens on download speed, not upload.
    Windows8 Pro
Go the route I went if you have a U.S. based ISP. I went with the Motorola/Arris SB6141 modem. Just changed to the Cisco RV-320 Router (You do not have to, there is the wireless routers that would work fine), and a Engenius ECB-350 Wifi Access Point when I went with Comcast.
I did not want the whole All-In-One gateway after dealing with the crippled way that ATT did with the U-Verse gateways. Having your own equipment. Gives you more flexibility.
I switched from a Trendnet TL-R600VPN Router to the Cisco. Because the Trendnet would drop the lease to my NAS and not renew it after 4 days.
    Linux Mint 17.2
    12GB
    Realtek HD
    LCD
    1366 x 768
    Logitech M525
    45/6 - ATT U-Verse
Slight update on this. When this occurs (after re-booting or unplugging the Ethernet cable & plugging it back in) I have now noticed that when I start a large download like a TBB test file that also kicks it back into life, ie full speed, without having to uninstall & re-installing the adapters.
It seems the adapters start in some sort of "sleep" mode after a re-boot or disconnect/reconnect & need a high throughput to "kick" them back into full life/speed. Some sort of setting needs adjusting?
    Windows8 Pro
The root of this may be in the bios. When the PC boots there is a "plug and play" process that assigns hardware addresses/resources to all of the devices attached to the motherboard. If this process messes up and causes a conflict between devices on boot you will see problems like this.
I had a problem like yours many moons ago, unfortunately I don't remember what I did to fix it. Also, I am sure that each PC and bios have their own settings and terminology for this. Hopefully this will at least get you started on a fix! One possible thing to try - if the adapters are separate physical devices, plug them into different slots or swap their positions and restart. That may make the process rerun and straighten itself out.
As a temporary fix have you tried sleep or hibernation instead of shutdown? I use sleep and go weeks between shutdowns or restarts. That way you won't have to fiddle with it as often.
    Windows 8.1 consumer 64 bit
    Acer Aspire M5 481PT-6644
    Intel Core I5
    6 GB
    ELAN Trackpad
    18mbs/5mbs
    Chrome
Another view on this.
I booted my system into safe mode with networking & the network adapters ran at full speed straight away without having to uninstall & re-install them. This must eliminate an adapter or driver fault.
Something must be causing this during a normal start up.
The question is what? And do you find out what it is?
    Windows8 Pro
OK, A final word on this.
I have managed to sort it. It was a programme called "AMD QuickStream" which was installed with the latest AMD graphics card driver/software a couple of weeks back. It's supposed to prioritise internet traffic like streaming but obviously doesn't work very well, just cuts your connection speed.
I have now uninstalled it & now everything is back to normal.
Thanks for all advice & help.
    Windows8 Pro
Glad you were able to fix it and thanks for reporting the solution - it may help others in the future.
    Intel Core I5
    6 GB
    ELAN Trackpad
    18mbs/5mbs
    Chrome
[COLOR = buseng; 376.844] tôi đã đột nhiên có một vấn đề lạ xảy ra. Mỗi khi tôi khởi động lại máy tính để bàn của Windows 8.1 của tôi tốc độ kết nối internet của tôi giảm từ đó là bình thường 50Meg khoảng 3Meg khi chạy bất kỳ chương trình SpeedTest. Cách duy nhất để chữa bệnh này là để gỡ bỏ cài đặt và cài đặt lại adapter mạng của mình thông qua quản lý thiết bị. Tất cả là ok sau đó cho đến khi khởi động lại tiếp theo của tôi và sau đó tất cả sẽ xảy ra một lần nữa. Nó là như nhau trên cả hai kết nối Ethernet và adapter không dây. Tôi đã thử cài đặt lại trình điều khiển vv vô ích. Một cái gì đó kỳ lạ về thiết lập mạng của tôi. Tôi cũng đã chạy quét virus khác nhau nhưng không có gì xuất hiện.
này đột nhiên bắt đầu hôm thứ Bảy và tôi không thể nhìn thấy những gì có thể gây ra của nó, đã không được cài đặt bất kỳ chương trình mới hoặc bất cứ điều gì.
Bất kỳ mối xin vui lòng vì nó là một mối phiền toái giữ cài đặt lại adapter mạng của tôi mỗi khi tôi khởi động lại.?
Tất cả các thiết bị khác của tôi là ok bao gồm một máy tính xách tay của Windows 8.1. [/ B]
step 1 : update windows .
step2 : test : http://*******/mTcyy
if still slow
step 3 : all the microsoft fix tool
http://*******/mTdkJ
thank you !!!!
Just click on the button at Test your Connection to perform a series of network tests for modern Web Services like WebSockets, WebRTC and XHR. A full profile of your browser, operating system and the environment will be created. A url will be given which you can then share with us to get your connectivity problem diagnosed.
    window 8
Many thanks for this solution! I have been searching a few days to solve a similar problem to yours, and uninstalling Quickstream did the trick! (Asrock AM1H-ITX).
This isn't limited to Windows 8(.1) only by the way, I also experienced this on Windows 7 (same system, I thought it might be a faulty Windows installation or something at first, so I switched between 7 and 8).
    Windows 7
Thank you so much for your posts. I wish I would have found this a week ago. I was having this exact same issue, and tried tons of other stuff. Uninstalling Quick Stream 100% fixed it for me. Now to try to undo all the other stuff I tried...
    CyberpowerPC Fangbook 210
    A10 quadcore
    16GB
    AMD HD8970M
Maybe you don’t have to uninstall AMD Quick Stream. The slowness is caused by AQS default setting in which Rate Auto Detection is turned on. You can download a later version of AQS from the website:
AMD Quick Stream Technology and install it on you PC.
    Win8
