need to combine or delete useless partitions...help
billberry12
Can someone tell me what all this means. I bought this laptop used, and it was restored to original settings supposedly by seller, but does this look right? What do I need to do?
    Surface Pro 3
    Intel I5
    4 GB
    128 GB SSD
    Chrome
    Windows defender and Malwarebytes
    Ccleaner from time to time. Not sure if this is necessary with 8.1??
    Pavillion H8-1202
    I7-2600 @ 3.4 GHz
    PEGATRON
    8 GB
    NIVDIA GeForce GT 520
    Realtek ALC656GR CODEC
    Samsung SyncMaster S22B350
    1920X1080 32 bit color
    Samsung 850 EVO SSD 500GB
    Logitech M510
Unfortunately, that's perfectly normal; for a Win 8 system running on a UEFI BIOS with a GOT hard drive. If none of that makes any sense to you, Google UEFI and GPT for more info. Ask any questions here and I'm sure someone can help.
Mine looks similar. Lenovo K450 running Win 8.1.1, 3 hard drives. Boot is a 250GB SSD.
    Windows 10 Pro X64
    Lenovo IdeaCenter K450
    Lenovo
    Intel Integrated HD Graphics
    Realtek HD Audio
    HP h2207
    1680x1050@59Hz
    250GB Samsung EVO SATA-3 SSD;
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    Windows Defender; MBAM Pro
    UEFI/GPT
    PLDS DVD-RW DH16AERSH
Ztruker,
If you say "Unfortunately, that's perfectly normal" I think that's good enough for me. I have just never seen anything exactly like this. Everything works as it should so I just need to leave it well enough alone huh? Why do you say "unfortunately"?
Thanks so much.
Bill
    Surface Pro 3
    Intel I5
    4 GB
    128 GB SSD
    Chrome
I tried to do an image or clone with Macrium free and it would not work. Said I had too many partitions??? That's the way I learned of all these partitions. How am I suppose to image or clone this disk? Ideas?
    Surface Pro 3
    Intel I5
    4 GB
    128 GB SSD
    Chrome
Macrium Free should work. I've not heard of anyone else having a problem with the number of partitions in 8.1. Maybe someone else here has some ideas on this?
I'll give Macrium Free a try just to see what happens. Will update later.
I use Acronis True Image 2014 for my backup and it has no problem with 6 partitions on the boot drive.
"Unfortunately" because it causes many people to think something is wrong. Some even start deleting the "extra" ones then end up with a non bootable, unusable system.
    Windows 10 Pro X64
    Lenovo
    Realtek HD Audio
    HP h2207
    1680x1050@59Hz
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    UEFI/GPT
Macrium Free works for me on Win 8.1.1. I just installed it and tried it.
    Windows 10 Pro X64
    Lenovo
    Realtek HD Audio
    HP h2207
    1680x1050@59Hz
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    UEFI/GPT
Yes, Macrium free worked for me too just now. I told you wrong. I was trying to make a rescue USB drive, and that's when it told me it could not because there were too many partitions on the drive. I don't have a cd/dvd burner. Ideas?
    Surface Pro 3
    Intel I5
    4 GB
    128 GB SSD
    Chrome
Can a Macrium Rescue boot be made on an external hard drive??
    Surface Pro 3
    Intel I5
    4 GB
    128 GB SSD
    Chrome
Don't know if an external HD can be used or not. Try it and let us know :)
Curious, why would you want to tie up a external HD as a Macrium Rescue disk? A cheap flash drive or DVD seems like a better option to me.
    Windows 10 Pro X64
    Lenovo
    Realtek HD Audio
    HP h2207
    1680x1050@59Hz
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    UEFI/GPT
