Need help, might be very simple for you
ashleymoco
I recently got a Windows 8 laptop, but one thing that really bugs me is the checkmark on the desktop icons. For example,
    HP
    intel inside CORE i7
    Internet Explorer
    Norton
That looks like it could be a Norton overlay but I'm not sure. The old way to get rid of those was to go into Norton settings and on the right side, uncheck "Backup Status Overlays". Then reboot.
    Intel G2020
    ASRock B75M-DGS R2.0
    8GBs @ 1333 MHz
    Samsung 840 EVO
    400w
To get rid of the tick, do this
You may also want to get rid of the shortcut arrow overlay.
If you've got a 64 bit machine go and download FxVisor64 from here ...
    Windows 7 Pro plus Windows 8.1 Pro VM
    Custom
    i7-3770K
    Gigabyte GA-Z77X-UD3H
    16 GB x G.SKILL Ripjaws
    GeForce GTX560
    Main - OCZ Vertex4 128 GB Solid Drive
    Sec - Hitachi Deskstar 7K1000D 1TB
    Seasonic X-760
    Coolermaster HAF912 ATX Mid Tower
    Corsair Hydro Series H80 CPU water cooler
    Eset
Hi DaddyG,
I did the opposite. I went into your suggested view, "ticked" the "item check boxes", and nothing changed on my desktop. The icons still look the same:
So, can you actually make those boxes appear and disappear on your desktop because I can't do it that way?
    Intel G2020
    8GBs @ 1333 MHz
    Samsung 840 EVO
    400w
You have to actually select something for the checkboxes to show up.
    Intel i7 3770K
    Gigabyte Z77X-UD4 TH
    16GB DDR3 1600
    nVidia GTX 650
    Onboard Audio
    2560x1440 + 2x 2048x1152
    Antec SOLO II
    Logitech MX
You can set check boxes in Folder Options too.
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Package Socket FT1 BGA
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
    Avast Internet Security
Wow, I never knew that! Thanks DaddyG, Mystere, and David... Hmm, I've only been here 7 days and I learned something new. Hope I was able to help a few OPs during that time because its tough when you finally get caught and make yourself look like a fool! Cheers and thanks again guys!
    Intel G2020
    8GBs @ 1333 MHz
    Samsung 840 EVO
    400w
You're no fool. :)
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
    Intel G2020
    8GBs @ 1333 MHz
    Samsung 840 EVO
    400w
