my CPU get over 100 C temp using hotcpu test
cruzhart
can anyone solve this? my CPU is burning,
i have an asus laptop A42JA with Intel® Core™ i5-460M Processor (2.53 GHz, Cache 3 MB)
some tech from BSOD forum told me it my BSOD is because overheating CPU
what should i do to lower the CPU temp? is it possible that the CPU itself is defective so it overheating?
this is temp when i do some Hotcpu test, it passed, memtest86+ passed too
this is temp at idle
and usually it start BSOD when i play 720p-1080p videos and opening multible tabs in instance on chrome
this is the crash dump print screen
  • SF_11-06-2013.zip
    WINDOWS 8 X64 Pro
Laptop + heat problems = needs cleaning from dust etc.
Hot CPU test is doing what it was made to do, loads CPU and than you see how hot it can get. Most heat related problems with laptops are dust related. coolers and fans are small and more sensitive than desktops.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
You could also try re-pasting the cpu, remove the heat sink, clean it with something like Arctic clean, use any thermal paste, clean the fan as well, it might reduce the temps.
    Win 8.1
    Acer Aspire E1-571
    i5-3230m
    Acer Type-2
    8GB DDR3 1333MHz
    Intel HD 4000
    High Definiton Audio Device
    Generic
    1366x768
    Samsung 850 Pro 256GB
    Generic
    QWERTY
    ELANTECH Touchpad
    12.68Mbps
    IE11
:ditto:
I've already fixed some laptops with similar problems, and in 90% of the cases cleaning the coolers and repasting resolved the overheating probs.
    Windows 10.0.10122
    My Build - Vorttex Ultimate
    Core i7 @ 4500 MHz
    ASUS Z87-Plus
    32GB DDR3 @ 1822 MHz (OC)
    7.1 HDA
    LCD LG 22" + CRT LG 17"
    1760 x 1320 / 1280 x 960
    1 x 240 GB SSD (System)
    3 x 500 GB HDD (Data/Media)
    1 x 2000 GB e-HDD (Backup)
    ThermalTake 1000W PSU
    Corsair Carbide R300
    Corsair H60 (Push-Pull)
    Microsoft Wireless Keyboard
    Microsoft Wireless Mouse
    60 Mbps (Down) 5 Mbps (Up)
    IE, FF, Chrome
    AVG Internet Security 2015
    Some wired stuff
actually two i've changed the paste, in CPU and VGA chips two weeks before i post this, and i don't think my cooler fan is not that dusty.. should i repaste it?
    WINDOWS 8 X64 Pro
You need to check whether the heat sink is properly seated, check whether you have not forgotten to lock the cpu, check whether you have plugged the fan and check the screws are hand tight. If you need to remove the heat sink again, you need to re-paste it.
    Win 8.1
    Acer Aspire E1-571
    i5-3230m
    Acer Type-2
    8GB DDR3 1333MHz
    Intel HD 4000
    Generic
    1366x768
    Generic
    QWERTY
    ELANTECH Touchpad
    12.68Mbps
    IE11
