Solved Low FPS in APB: Reloaded Menu Screen
Chuck38
Just livin life
Hi everyone,
I was playing APB: Reloaded quite a bit on Windows 10. However, my Bluetooth headphones don't work with Windows 10, so I decided to re-install Windows 8.1. I did and that's what I'm on now.
I re-installed APB: Reloaded onto Windows 8.1 and now every time I start the game up, where it's at the log-in screen, it seems to be running at 2-3 FPS!! :mad:
It never did this in Windows 10. Any help will be greatly appreciated. :)
-Chuck
    Windows 10 Pro 64-bit
    Self-built/ Custom
    AMD FX-6300
    MSI 970A-G43
    Crucial Ballistix Sport 8GB
    Asus GTX 750 ti
    HP w2207h
    1680x1050
    Seagate 1TB 3.5" 7200 Hybrid Internal Hard Drive
    Crucial M500 240GB 2.5-inch Internal SSD
    EVGA 500 Watt 80+ Certified ATX Power Supply
    Fractal Design Define R4
    Corsair Hydro Series H55 Quiet Edition Liquid CPU Cooler
    CM Storm Devastator - Red
    Logitech Wireless Performance Mouse MX
    Really fast.
    AVG
    Logitech G230 Headset
sygnus21
Have you tried checking drivers? Both Sound and video?
BTW do you have a link to the game?
Thanks.
    Custom built by me
    Haswell i7-4770K
    Gigabyte G1 Sniper 5 (BIOS F9)
    Corsair Dominator Platinum 32 gig (1866MHz)
    Sapphire R9-280 Vapor X
    Soundblaster ZXR
    NEC PA242W - 24 inch
    1920 x 1200
    Samsung 512gig 850 Pro SSD (OS), Samsung 256gig 840 Pro SSD (photo editing), Western Digital Caviar Black 2TB HD
    EVGA Supernova 1000 G2
    Cooler Master HAF X
    Corsair H100i Closed Loop Cooler
    Logitech Wireless Wave
    Logitech Performance MX
    High Speed
    IE11
    Norton Security
    RAM Speed: 1866MHZ @ 9-10-10-27-2T, 1.5v
Chuck38
Just livin life
Thanks.
I haven't checked my drivers yet. I just assumed that after re-installing 8 it would install the latest drivers.
As for a link to the game, I downloaded it off of Steam. APB Reloaded on Steam
    Self-built/ Custom
    AMD FX-6300
    MSI 970A-G43
    Asus GTX 750 ti
    HP w2207h
    1680x1050
    Really fast.
    AVG
Chuck38
Just livin life
Okay, I'm installing the drivers. I'm thinking there were no drivers at all!
When I had Geforce Experience scan for drivers, it couldn't find anything! :eek:
    Self-built/ Custom
    AMD FX-6300
    MSI 970A-G43
    Asus GTX 750 ti
    HP w2207h
    1680x1050
    Really fast.
    AVG
sygnus21
Any time you reinstall an OS you should always get the latest device drivers from the manufacturers website and not just rely on the OS drivers from Microsoft, especially with regards to sound and video drivers. That said check the vendors site for the latest drivers, download and install them.
Let us know.
    Custom built by me
    Haswell i7-4770K
    Soundblaster ZXR
    1920 x 1200
    Cooler Master HAF X
    High Speed
    IE11
    Norton Security
Chuck38
Just livin life
That did the trick! I installed the latest drivers and it's working perfectly!
Thanks for your help! :)
-Chuck
    Self-built/ Custom
    AMD FX-6300
    MSI 970A-G43
    Asus GTX 750 ti
    HP w2207h
    1680x1050
    Really fast.
    AVG
sygnus21
Well there you go. Happy gaming.
And thanks :)
BTW if you have any other gaming issues, you should check out my game troubleshooting guide - Tips on Troubleshooting Game Issues
Peace :cool:
    Custom built by me
    Haswell i7-4770K
    Soundblaster ZXR
    1920 x 1200
    Cooler Master HAF X
    High Speed
    IE11
    Norton Security
