Lebon14, I disagree. I don't think that Windows 8 is directed at businesses. Before Win 7, most businesses were scraping by on XP. XP met all of their needs and there was no reason to upgrade to Vista. Once Win 7 came out and proved itself to be a really good, stable platform, businesses started making the switch-over to it--to the point where there are more Win 7 machines than XP machines now.
It is unlikely that businesses would move to Win 8 after having gone to the expense of changing over to Win 7. I suspect that most businesses will give Windows 8 a pass and wait for the next evolution, so your concern over businesses and big enterprises ignoring Win 8 is moot.
For any businesses that might decide to go with Win 8, there won't be any need to rewrite programs which work on Win 7, because they will also work on 8.
As for touchscreens, there are a number of them available in flat-screen LCD monitors and with the introduction of a large scale operating system like Win 8, there will be a growing number and they will get cheaper and cheaper as sales rise.
Just my opinion. Cheers
I think a lot depends on the type of company you work for. If your work is on the cutting edge of technology, then you are probably correct, but if you work for a large corporation, they simply cannot afford to switch OSes with every evolutionary step. Remember that Win 7 is actually Win 6.1 and Win 8 will be Win 6.2 (Vista was Win 6.0) so backwards compatibility is there for virtually all programs. Also remember that we are still only on Win 7 SP1 and SP2 probably won't be released for another 6-9 months--about the same time as Win 8.Lebon14, I disagree. I don't think that Windows 8 is directed at businesses. Before Win 7, most businesses were scraping by on XP. XP met all of their needs and there was no reason to upgrade to Vista. Once Win 7 came out and proved itself to be a really good, stable platform, businesses started making the switch-over to it--to the point where there are more Win 7 machines than XP machines now.
I disagree. In my company I work for once the software we use is supported in a new OS we switch over to it. Many software providers will not support what they call a legacy OS for tech support. So if we have a issue say with running the program on Windows 7 and 8 is now supported they will not give any tech support. Bear in mind we use high end engineering programs.
Windows 7 cheaper? Uhh Windows is not sold like a car it doesn't get cheaper when a new version comes out. The old version is no longer sold.
Wrong. It's called supply and demand. You can buy Vista and XP for less than 7. You can still buy Windows 95. You can buy 3.1.
Colonel...I'm sure you are smarter then this. Business buy their operating systems in bulk. Volume Licensing. Not old unsold warehouse retail boxes. Or pre-owned sold by owner deals.
