Increased Fan Volume when Idle
farzadmf
Hi everybody,
I have Windows 8 installed on my laptop, and there's something I can not figure out. Whenever I leave my computer and it's in idle mode, it seems that something starts to run which causes my fan noise to increase. As soon as I move the mouse or press a key on the keyboard so that my screen is ON, my fan noise goes back to normal. Does anyone have any suggestions? There have been situations where I have left the room and when I come back after about 10 minutes, my fan noise was relatively HIGH.
Thanks
    Windows 8 x64
    Sager NP9150
    Intel Core i7 3720
    24 GB
    nVidia GeForce 675MX
    Mozilla Firefox
    Norton Internet Security
something is running in the background when idle, could be maintenance, virus scanner, backups, etc...
Since it ceases when your computer stops being idle, it may be difficult to track.
I suggest looking in your scheduled tasks and see if you find it there..
go to your start screen and start typing task options will pop up and select task scheduler
you will see what has been running in the past 24 hours first you can change that to last hour, day, etc..
Look for optimizers or scanning programs in the list..
    HP G60
    3 GB
    Nvidia GeForce 8200M G
    1366 x 768
    Chrome and Chromium
    Avast Free & Malwarebytes
Thank you for your answer,
When I go to Scheduled Tasks nothing appears even if I change it "Last 30 days". Isn't there any program which I can run and then leave my computer in idle and this program records what happens in the background, so that I can check it?
    Windows 8 x64
    Sager NP9150
    Intel Core i7 3720
    24 GB
    Mozilla Firefox
ok, lets try this..
in the start menu start typing event viewer, a shortcut should appear to event viewer
select it
click application, maximize full screen, stretch out the source tab to see more detail..
this will show all applications that have run already and are currently running as well including failed starts..
    HP G60
    3 GB
    1366 x 768
    Chrome and Chromium
ok, lets try this..
select it
Actually, when I type "event" (or "event viewer"), there's only a View event logs option (in the "Settings" section), and when I open it up, there's no "application" that I can click
I uploaded a screenshot for you to see...
    Windows 8 x64
    Sager NP9150
    Intel Core i7 3720
    24 GB
    Mozilla Firefox
This works fine as well...
goto log summary
double click application
and browse through that to see what programs are/were running..
Or you can allow your computer to sleep
then wake it up about a minute after you hear the fan speed kick up,
note the time and date, then look at the event viewer/applications for that timeframe..
    HP G60
    3 GB
    1366 x 768
    Chrome and Chromium
goto log summary
Thank you, I will try that and see if I can find anything...
    Windows 8 x64
    Sager NP9150
    Intel Core i7 3720
    24 GB
    Mozilla Firefox
Just as a side note, do you have any system optimization/hard disk care/defrag programs installed? If so, that could be causing your problem.
    Windows 8 Professional x64
    Custom Build
    Intel i7-2600k
    ASUS Sabertooth P67 B3
    G.Skill Ripjaws X DDR3 2x4GB 1600MHz
    ASUS GTX580DCUII
    Corsair TX850v2
    Coolermaster HAF X
    Too much!
    Internet Explorer 10
Unfortunately not, and I cannot figure out what runs in the background...
    Windows 8 x64
    Sager NP9150
    Intel Core i7 3720
    24 GB
    Mozilla Firefox
goto log summary
It's interesting, I cleared up the whole "application" log, and my computer went to idle. Fan noise began to increase a little bit, then I opened the log, and there was no log for an application for that time...
    Windows 8 x64
    Sager NP9150
    Intel Core i7 3720
    24 GB
    Mozilla Firefox
It's most likely the defragmenter, but I would also suspect any proprietary software that the manufacturer/retailer has onboard as they may be scanning for "upgrades".
    Win 7 Ult SP1 + Win 10 Pro - (x64)
    Alienware® ALX X58
    Intel® Core i7-975 Extreme 3.86 GHz 8MB Cache
    ASUS P6T Deluxe V2 Socket 1366 Core i7, Dual Triple Channel DDR3 Mem
    24GB Corsair Vengeance DDR3 SDRAM at 1600MHz - 6 x 4096MB
    1792 MB NVIDIA® GeForce® GTX 295/Hauppauge HVR2250 TV Tuner
    Onboard Soundmax® High definition Sound
    Samsung XL2370 LED
    1920 X 1080P
    2 X 500gb SATA
    1 X 1TB SATA
    1 X 3TB external eSATA
    (Non-RAID)
    Alienware® 1200 Watt Multi-GPU
    Alienware® P2 ALX Chassis with AlienIce 3.0 Video Cooling
    Alienware® High-Perf. Liquid Cooling + Acoustic Dampening
    Microsoft® Wireless Entertainment 8000 + Logitech® G15 Wired
    Microsoft® Wireless Laser 8000 + Logitech® G9 Wired
    1tbs
    Using non-RAID on purpose as I find it too fussy and temperamental.
goto log summary
What antivirus do you have?
Can you post a screenshot of ALL the processes running on your machine from the task manager? (You have to click the "Show processes from all users..." button.)
    Custom Build
    Intel i7-2600k
    ASUS GTX580DCUII
    Corsair TX850v2
    Coolermaster HAF X
    Too much!
goto log summary
I'm using Norton Internet Security,
About the screenshot, unfortunately the list is so long I don't know how to include all the items in one screenshot :(
    Windows 8 x64
    Sager NP9150
    Intel Core i7 3720
    24 GB
    Mozilla Firefox
Hello, farzadmf.
How old is the laptop? Does the fan roar when you use it?
It could be a matter of dust blocking cooling.
    8.1 Pro X64
    Acer T690
    Intel Pentium D Dual Core
    Acer/Intel E946GZ
    2GB (max upgrade)
    Acer AL1917W A LCD
    1440 X 900
    Thumb drives
    Standard 250 watt
    Dual case fans + CPU fan
    Acer Windows PS/2
    Wireless Microsoft Arc
    54mbp/s
    IE11
    Defender
Hello, farzadmf.
I don't think so, I bought the laptop about 2 months ago.
The fan noise isn't that bad when idle; I was just wondering what causes this situation. That's the reason I decided to ask here and use other people's experience.
Thank you anyway
    Windows 8 x64
    Sager NP9150
    Intel Core i7 3720
    24 GB
    Mozilla Firefox
this seems a better option as I'm facing the same trouble in my HP 520 laptop and now going to check the log summary .. hope i get there an apt solution...
    e4166
    core 2 duel
    i3
    Dell
    compe
    kpersky
Many screenshots is OK, too :geek:
    Custom Build
    Intel i7-2600k
    ASUS GTX580DCUII
    Corsair TX850v2
    Coolermaster HAF X
    Too much!
OK, I attached 5 JPG files. Hope it helps...
    Windows 8 x64
    Sager NP9150
    Intel Core i7 3720
    24 GB
    Mozilla Firefox
That list helped a lot, thanks :thumb:
My first two suspects are Norton and VMware, why don't you give disabling VMware and checking Norton's Schedule to see if it has anything programmed to run at idle time?
-Julian
Microsoft Student Partner
    Custom Build
    Intel i7-2600k
    ASUS GTX580DCUII
    Corsair TX850v2
    Coolermaster HAF X
    Too much!
Hello, farzadmf.
Thank you anyway
You're quite welcome. :)
I understand now. I see it's not a huge problem. You're just curious as to why the fan runs a little faster. Good luck in your search.
    8.1 Pro X64
    Acer T690
    Acer/Intel E946GZ
    2GB (max upgrade)
    Acer AL1917W A LCD
    1440 X 900
    Thumb drives
    Standard 250 watt
    Acer Windows PS/2
    54mbp/s
    IE11
    Defender
