Solved How to Hide System reserved drive?
remostalin
    windows 8.1
    AVG 2014
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
XweAponX
You should remove the Drive letter if you can... Usually partitions like that do not have drive assignments within Windows, don't know why it was assigned in your case. Hm... Ive had it happen to me a few times working on clients machines, the Reserved Partition was being given Drive C before even booting Windows. In Windows it was some other letter, but being set as C while booting was preventing the system fro booting to the OS, it was only bringing up the Restore Partition. Removing the letter didn't help either. (Clarification: The Motherboard was assigning that partition as C- using other Bootable Media, exploring the drive would show that partition as C).
I had to fix the MBR using Partition Wizard, and then use Fixboot and FixMBR, it was XP. That was the only way to deal with it,
    AMD 4400+/4200+
    2 GB/3GB
    GeForce 8400 GS/GeForce 210
    Hitachi 40" LCD HDTV
    "1842 x 1036"
    WD My Book 1140 USB Device
    Works 550w
    MSI "M-Box"
    Water Cooled
    Dell Keyboard
    Microsoft Intellimouse
    Cable Medium Speed
    Chrome/IE 10
    Eset NOD32 6.x/Win Defend
remostalin
Thank you :)
Go to Start screen > type Computer > right click at This PC ( or Computer ) > select Manage > left panel, click Disk Management > wait for it to load > right click at System Reserved G > select Change Drive Letter or Paths > highlight G > select Remove > OK
    windows 8.1
    AVG 2014
You're most welcome. :)
    Lumia 1520 phone
