Solved How to add operating system to system start-up list
robbybobs
Hi, I have three operating systems on my pc. I only recently installed a windows 7 64 bit on a ssd but after doing so, I had to do a system image recovery to my windows 8 installation from a date prior to the new windows 7 install. This Windows 7 is not on the list of operating system options in system startup so how do I add it?
Thanks
Robby
    windows 7 windows 8
    self build
command corrected, albeit late
Hi,
Post the full screenshot of diskmgmt.msc and the result of bcdedit /enum all
Explain where your Windows 7 is.
    Windows 8 Pro x64
    HP Pavilion dv7t (17.3'', i7-2630QM, HD 6770M 1Gb, 8Gb RAM, 2 SSD@120Gb + 1 HDD@750Gb)
Hi, The two screen shots are attached but I couldn't run [FONT=&amp]bcdedit /enumall just [/FONT][FONT=&amp]bcdedit /enum, is that a problem? The Windows 7 64 bit that I'm trying to get an entry for in located on drive T.[/FONT]
Thanks
    windows 7 windows 8
    self build
I lost a space in the command. Please run
bcdedit /enum all >>%userprofile%\desktop\bcdedit.txt
and attach the text file from your desktop
    Windows 8 Pro x64
Hope this is correct!
  • bcdedit.txt
    windows 7 windows 8
    self build
Boot into the recovery environment
shutdown /r /o /t 0
In the command prompt, enter
bootrec /rebuildbcd
This switch looks for Windows installations on local drives (similar to /scanos) and offers to add the absent ones to BCD. So if you have Windows on T, it will add it (drive letters are different in RE, though).
    Windows 8 Pro x64
