How do I print from Onedrive?
Autobahn
176
I have uploaded documents to Onedrive using Microsoft Office Lens using my Android mobile.
That went well.
I was then going to use my Windows 8.1 laptop to go to Onedrive and print a copy of each document, but there is no 'print' button to click on.
Thanks
    Windows 8.1 update 1
    Dell Inspiron 15R special edition
    Intel Core i5-3210M CPU @ 2.50GHz
    Intel HD Graphics 4000
    Avast
strollin
Old Guys Rule!
N. Calif
2,761
When you say "Print from OneDrive" are you talking about printing a document that's in the OneDrive folder on your local computer or are you trying to print a document listed on the OneDrive website?
Either way, I was able to print Office documents but it appears that in order to print a document from the OneDrive folder on your local computer, you need to have Office installed there. Do you have Office installed on your computer? The native OS doesn't know how to print an Office document so, in order to print a document, it must be opened by Office and then sent to the printer.
Even if you don't have Office installed on your local computer, you should be able to login to OneDrive.com, locate the docs there, open them on-line and print them.
    W10 Pro (desktop), W10 (laptop), W10 Pro (tablet), W10 (laptop)
    Home built i7-3770K, Toshiba Satellite S55-A Laptop, MS Surface Pro 3, Dell Inspiron 15 5000
    4.0Ghz Core i7-3770K, 2.4Ghz Core i7-3630QM, 1.9Ghz Core i5 4300U, 2.8Ghz Core i5 6200U
    ASUS P877-V LE Plus, Toshiba, MS, Dell
    16G, 12G, 4G, 8G
    Nvidia GTX 1050, Intel HD Graphics 4000
    ATI High Definition Audio (Built-in to mobo)
    Dell S2817Q 28", 15.6"
    3840x2160, 1366x768 (laptop)
    240GB ssd boot drive with 1.5, 2.0 & 4.0TB Data on Desktop, 512GB ssd for laptop, 128GB SSD tablet, 500GB ssd laptop
    Antec EA-650 Green
    Antec 100
    Coolermaster CM 212+
    IBM Model M - used continuously since 1986
    Microsoft IntelliMouse
    120Mbps/6Mbps down/up
    FireFox
    MSE on desktop, Defender on laptop
    Retired after working in the tech industry for 41 years. First 10 years as a Technician, the rest as a programmer/software engineer. After 1 year of retirement, I was bored so went back to work as a Robotic Process Automation Consultant.
Autobahn
176
Yes, print from the 'Onedrive website'.
Their website does not seem to have a 'print' button when I click on a document?
The only way I could get it to work was to download each document onto my computer and then I was able to print them from there.
Has something gone wrong with 'Onedrive' or has it never had a 'print' button to click on, and if not, why not?
    Avast
strollin
Old Guys Rule!
N. Calif
2,761
As I said earlier, on the OneDrive website you need to OPEN the document on-line, then you can print it.
    16G, 12G, 4G, 8G
    Antec EA-650 Green
    Antec 100
    FireFox
