How do I format a secondary hard drive with a different OS
holidayhawk
My laptop has to terabyte hard drives, one which has Windows 8 and one that has Ubuntu 14.04. I use to use Ubuntu quite a bit, but all the more I really use my laptop for is to play games, so Ubuntu has been getting used less and less over the last couple of months. I've thought about getting rid of Ubuntu, and turning that hard drive back into simply being a secondary hard drive for Windows, but I can't seem to find out how to do it? Should I decide to do this, how do I?
TechnoMage
Active Member
Does Windows Explorer even SEE that drive?
If it does, you can right click on that drive in Windows Explorer (MyComputer) and select "Format".
Since the drive does not have a DOS or NTFS compatible format, working with it from Windows may not be possible. I've had that problem before, with Linux formatted drives.
I could remove that Linux partition with FDISK, a DOS program that I keep on my DOS Utilities CD.
Then make just one partition using FDISK and then DOS Format the drive, then windows could see it and reformat it as NTFS, if indeed that's what you want.
Personally I keep my extra drives formatted FAT-32, so I can access them and the files I store on them, even from a DOS boot disk. (not so, with NTFS) For instance, most USB Drives come already formatted FAT-32.
If you were local, I could fix that problem for you. :dinesh:
Good Luck, and Happy Holidays
:cool:
    Win-8.1/Pro/64
    Home Made
    AMD 8 Core
    Gigabyte, Ultra Durable, GA-970A-DSP3
    Crucial, 8GB
    AMD Radeon HD 5450 (2 GB)
    On Board
    24" LG
    Sandisk, SSD 120GB, 8TB Seagate backup drive
    Antec Earthwatts, 650
    Pac-Man Case
    HP Professional
    GearHead Wireless
    5 Meg
broe23
Retired from the grind
You would just format the other drive under Drive Management. Or use a Linux Live DVD and use Gpartd, to format the drive as a Fat32 or NTFS drive.
    Linux Mint 17.2
    12GB
    AMD Radeon™ HD 7310 Graphics
    Realtek HD
    LCD
    1366 x 768
    Crucial M500 240GB SSD
    Logitech M525
    45/6 - ATT U-Verse
    None needed. It is Linux.
Tommy456
Try 3-rd party partition software like Partition Master or Gpartd on Windows system. Or create the winpe disk USB of partition or Gparted on windows hard drive, then restart the computer on Ubuntu, in Winpe you can format the external disk.
    Windows8
Cliff S
Missing my GIF avatars:(
One problem will be your GRUB menu after you destroy the Ubuntu partition. Your computer will not be able to find an OS after. I know there are commands to rebuild the MBR in windows 7, but you might want to research how to do that in windows 8 with GPT if you´re using it, otherwise you´ll have to reinstall windows or reimage.
Check this out at Ubuntu forums.
    Cliff's Black & Blue Wonder
    Intel Core i9-9900K
    ASUS ROG Maximus X Hero
    hanteks Enthoo Pro TG
    Trust GTX THURA
    Trust GTX 148
    25+/5+ (+usually faster)
    Edge; Chrome; IE11
    Router: FRITZ!Box 7490
pcgeek11
You can do everything you want with Windows disk management. Delete all the partitions and create new one(s) as desired.
pcgeek11
That was already suggested in post #3 and in post #4, the OP said that it does not see the drive.
No. He said the drive doesn't show in Windows. I can assure you if the drive isn't damaged it will show the Linux Partitions in Disk management. I dual boot Linux and have for many years.
play2mefish
:cool:
I just thought I would through my 2 cents out here...you can boot from a floppy and access a NTFS drive using NTFS for DOS. It's not pretty but it does work. Here is a link:
Free NTFS Bootdisk, NTFS4DOS, NTFS Boot CD
Enjoy!
    Windows 8 Pro
    ASRock 990FX Killer
    AMD FX 8320
    ASRock 990 FX Killer
    32gb
    Gigabyte GTX 750i
    Realtek (Stock on MB)
    ASUS 27 HD Monitor & a 37" LCD HD TV Screen (For movies)
    1 250 GB SS hard drive for OS
    1 1TB hard drive for data / mirrored to a second 1 TB hd.
    650W
    No name tower
    Enermax Liqtech 240
    Logitech
    Logitech
    Dnload 10.48 Upload .48
    IE 11 and Chrome when IE doesn't work
    F-PROT
