Help with DOS syntax for file deletion
martienne
European Union
128
I am looking for the correct DOS syntax to achieve the following:
In folder "C:\ABC":
1) Delete ALLA folders, including their content.
2) Delete any files that are in the root of "C:\ABC"
I have tried a combination of RMDIR and DEL but I am not managing to delete folders.
I can't find any examples of syntax online.
Any idea how to achieve this?
    Win 8.1
    i5
    ASUS
    24 GB DDRAM3
    NVIDIA GT430 x2
    Audial
    2 x 28" Sharp
    1360 x 768
    Samsung, Seagate, Toshiba, Hitachi, Western Digital
    750 watt
    liquid closed
alphanumeric
slightly off center
Gold Member
Technically its not DOS, its a command shell. Have a look at this, Del Try del /? for a list of options.
    Windows 10 Education 64 Bit
    Asus
    Thermaltake TR 620
    Stock heatsink fan
    Logitech Wireless K350 Wave
    80 Mbps Down 30 Mbps Up
oneeyed
328
Use DELTREE
Syntax : DELTREE [/Y] [drive:]path [[drive:]path[...]]
So in your case : DELTREE /Y C:\ACB
It will delete the ACB directories and all its subdirectories, files included. The /Y switch suppresses the prompt that asks for confirmation of each folder's deletion.
You'll have to recreate the directory though. You can still do that under the command shell, type :
C: (redirects you to drive C)
CD \ (redirects you to the root of the drive)
MD ACB (creates the directory)
Be careful with DELTREE, it can be very dangerous if not used right.
Edit :
My bad, DELTREE doesn't exist anymore in this version of windows (still existed under XP I think, sigh). Here is the equivalent now :
rd C:\ACB /s
    Windows 8.1 (x64)
topgundcp
San Jose - California
2,847
Use: rd /S /Q [dir] ======> [dir] is the folder you want to remove => remove everything in [dir] including [dir] itself.
    Home Brewed
    I7 4970K OC'ed @4.7 GHz
    MSI-Z97
    NVIDIA GeForce GTS 450
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    Logitech Performance Mouse MX
    35/12mbps
