HELP PLEASE - Multiple Users and Multiple Screens Question
jjthekyd
1
Hey guys thanks for reading this post.
For work, I run software that can only be opened a single time on a computer - no way around it - however, on my Windows 8 computer, I figured out that I can open the software on different user accounts on the same computer, and the software runs perfectly on the 3 accounts simultaneously when it is activated.
I am very annoyed by having to switch back and forth between three user profiles dozens of times a day to check up on the software and errors, so my big question is:
Say my main user profile is "Joe" and my second profile is "Bob" and my third profile is "Teddy", is there any way I can have one of my monitors always display Joe's screen/activity, while another monitor always display Bob's screen/activity, and my third monitor always display Teddy's screen/activity - essentially I have three user profiles running simultaneously at all times, and I want to see each of them individually on my three screens.
(These user profiles on the same computer of course, again just hate switching back and forth.)
Any help or advise would be greatly appreciated.
Thanks!
Jay
23,928
Hello Jay, and welcome to Eight Forums.
You might consider using a virtual machine instead. This way you could have the program running in each separate virtual machine, and be able to view them as separate opened windows from within your account.
Hope this helps, :)
    3 x 27" Asus VE278Q
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
Mystere
1,925
Unfortunately, Microsoft does not allow multiple users to be interactive on Desktop versions of windows at the same time. For instance, you can connect to your desktop machine with Remote Desktop from another computer, but it will log you out of the console when you do. Thus, while you can switch between users, you can only have one be "interactive" at one time.
Brink's suggestion is a good one, if you have enough resources to run more than one virtual machine at the same time.
    Intel i7 3770K
    Gigabyte Z77X-UD4 TH
    16GB DDR3 1600
    nVidia GTX 650
    Onboard Audio
    2560x1440 + 2x 2048x1152
    Antec SOLO II
    Logitech MX
XweAponX
What Program is it, maybe we can help you find a way around the multiple instances thing.
    AMD 4400+/4200+
    2 GB/3GB
    GeForce 8400 GS/GeForce 210
    Hitachi 40" LCD HDTV
    "1842 x 1036"
    WD My Book 1140 USB Device
    Works 550w
    MSI "M-Box"
    Water Cooled
    Dell Keyboard
    Microsoft Intellimouse
    Cable Medium Speed
    Chrome/IE 10
    Eset NOD32 6.x/Win Defend
