For starters:
At work we start all repairs with a set of diagnostics. Often they find problems that weren't even expected. It's a waste of time to try to fix software on a system that has hardware problems.
Please try these free diagnostics for starters:
Initial Hardware Diagnostics
Also, please ensure that you have
ALL available Windows Updates (it may take several trips to get them all).
Your BIOS dates from 2010. Please check at the manufacturer's website to see if there are any BIOS updates available for your system. Also check the readme file to see if they apply to the problems that you are having. Please be advised that flashing the BIOS is a very unforgiving process - and one mistake can physically damage your motherboard.
If you're overclocking, please stop the overclock while we're troubleshooting. Feel free to resume the overclock once the system has been stabilized.
The memory dumps blame video. It may be software, hardware, or a compatibility issue.
First step is:
- download a fresh set of the latest, Win8.1 compatible video drivers for your video card from
Visual Computing Leadership from NVIDIA
- uninstall the current video drivers from your system
- install the freshly downloaded drivers
- Monitor for further BSOD's
Other steps:
- run the free hardware diagnostics (especially the video tests) at:
- run the suggestions here:
Video TDR Timeout - 0x116 + 0x117 - Sysnative Forums
- update your chipset drivers to the latest, Win8.1 compatible version. If updates aren't available for Win8.1, you may have to consider that the system isn't compatible with Win8.1 (and you may have to revert to a previous version of Windows in order to get acceptable performance).
mvxxmm.sys Mon Nov 22 02:00:18 2010 (4CEA1502)
Marvell Aux NV Bridge DLL - related to mv91xx SCSI HD Controller
http://www.carrona.org/drivers/driver.php?id=mvxxmm.sys
mv91xx.sys Mon Nov 22 02:00:45 2010 (4CEA151D)
Marvell MV91xx AHCI/RAID driver
http://www.carrona.org/drivers/driver.php?id=mv91xx.sys
Analysis:
[font=lucida console]**************************Sun Oct 27 04:16:29.025 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\102713-16921-01.dmp]
Windows 8 Kernel Version 9600 MP (8 procs) Free x64
Built by: [B]9600[/B].16404.amd64fre.winblue_gdr.130913-2141
System Uptime:[B]0 days 3:39:11.776[/B]
*** WARNING: Unable to verify timestamp for nvlddmkm.sys
*** ERROR: Module load completed but symbols could not be loaded for nvlddmkm.sys
Probably caused by :[B]nvlddmkm.sys ( nvlddmkm+1a06e9 )[/B]
BugCheck [B]133, {0, 501, 500, 0}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x00000133]DPC_WATCHDOG_VIOLATION (133)[/url]
Arguments:
Arg1: 0000000000000000, A single DPC or ISR exceeded its time allotment. The offending
component can usually be identified with a stack trace.
Arg2: 0000000000000501, The DPC time count (in ticks).
Arg3: 0000000000000500, The DPC time allotment (in ticks).
Arg4: 0000000000000000
BUGCHECK_STR: 0x133
DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
PROCESS_NAME: System
FAILURE_BUCKET_ID: [B]0x133_DPC_nvlddmkm+1a06e9[/B]
CPUID: "Intel(R) Core(TM) i7 CPU 930 @ 2.80GHz"
MaxSpeed: 2800
CurrentSpeed: [B]2968[/B]
Processor may be overclocked!
Expected Frequency: 2800
Actual Frequency: 2968
Overclock Ratio: [color=red]1.06[/color]
BIOS Version P1.70
BIOS Release Date 05/27/2010
Manufacturer To Be Filled By O.E.M.
Product Name To Be Filled By O.E.M.
[/font]
3rd Party Drivers:
[COLOR=RED][B]mvxxmm.sys Mon Nov 22 02:00:18 2010 (4CEA1502)[/B][/COLOR]
[COLOR=RED][B]mv91xx.sys Mon Nov 22 02:00:45 2010 (4CEA151D)[/B][/COLOR]
Rt630x64.sys Fri May 10 05:59:08 2013 (518CC4EC)
nvhda64v.sys Sun Jun 16 08:38:07 2013 (51BDB1AF)
nvvad64v.sys Tue Aug 20 07:29:10 2013 (52135306)
intelppm.sys Thu Aug 22 04:46:35 2013 (5215CFEB)
NdisVirtualBus.sys Thu Aug 22 07:36:25 2013 (5215F7B9)
ahcache.sys Thu Aug 22 07:39:54 2013 (5215F88A)
werkernel.sys Thu Aug 22 07:40:24 2013 (5215F8A8)
intelpep.sys Thu Sep 19 03:12:46 2013 (523AA3EE)
nvlddmkm.sys Tue Oct 15 16:27:18 2013 (525DA526)
[/font]
http://www.carrona.org/drivers/driver.php?id=nvhda64v.sys
http://www.carrona.org/drivers/driver.php?id=nvvad64v.sys
NdisVirtualBus.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
ahcache.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
werkernel.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
intelpep.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
