help me to solve Unexpected_Kernel_Mode_Trap
usasma
Mr. Cranky Pants
Yes it does take a couple of days, when I have a new grandson to take care of, a yard to keep up, and a job (not to mention other family duties).
I apologize for the delay, but there's just not that many of us who specialize in BSOD repairs.
FYI - I logon once a day and I do as many posts as I can. Yesterday I didn't have time to come to this forum, so that's why it took 2 days.
No Windows Updates installed. Most systems have 66 or more. Please visit Windows Update and get ALL available updates (it may take several trips to get them all).
You have a EnGenius 802.11n Wireless USB Adapter:
I do not recommend using wireless USB network devices. Especially in Win7/Win8 systems.
These wireless USB devices have many issues with Win7(and I suspect with Win8) - using Vista drivers with them is almost sure to cause a BSOD.
Should you want to keep using these devices, be sure to have Win7/Win8 drivers - DO NOT use Vista drivers!!!
An installable wireless PCI/PCIe card that's plugged into your motherboard is much more robust, reliable, and powerful.
These devices have problems in Device Manager:
Generic Bluetooth Adapter USB\VID_0CF3&PID_3002\6&58952F4&0&4 43
PCI Simple Communications Controller PCI\VEN_8086&DEV_1C3A&SUBSYS_04B01028&REV_04\3&11583659&0&B0 The drivers for this device are not installed.
Please install the latest, Win8 compatible drivers for your BlueTooth.
Please installed the latest, Win8 compatible chipset drivers for your system. You may have to get these from Intel if Dell doesn't offer them.
All of the BSOD's blame your Intel Graphics drivers. Please update them to the latest, Win8 compatible version. As they date from 2012, you may also want to run these free hardware diagnostics (start with the video tests): Hardware Diagnostics
RTL8192su.sys Mon May 9 05:07:39 2011 (4DC7AEDB)
Realtek RTL8192SU Wireless LAN 802.11n USB 2.0 Network Adapter Driver
http://www.carrona.org/drivers/driver.php?id=RTL8192su.sys
tixhci.sys Wed Jul 20 14:36:12 2011 (4E27201C)
Texas Instruments USB 3.0 Host Drivers - TI XHCI Host Controller Driver
http://www.carrona.org/drivers/driver.php?id=tixhci.sys
tihub3.sys Wed Jul 20 14:36:29 2011 (4E27202D)
Texas Instruments USB 3.0 Host Drivers - TI USB3 Hub Driver
http://www.carrona.org/drivers/driver.php?id=tihub3.sys
Rt630x86.sys Wed Oct 19 08:13:13 2011 (4E9EBED9)
Realtek 8101E/8168/8169 NDIS 6.30 32-bit Driver
http://www.carrona.org/drivers/driver.php?id=Rt630x86.sys
Analysis:
[FONT=lucida console]**************************Fri Jun 14 20:48:26.127 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\061513-20312-01.dmp]
Windows 8 Kernel Version 9200 MP (4 procs) Free x86 compatible
Built by: [B]9200[/B].16384.x86fre.win8_rtm.120725-1247
System Uptime:[B]0 days 0:27:38.848[/B]
*** WARNING: Unable to verify timestamp for igdkmd32.sys
*** ERROR: Module load completed but symbols could not be loaded for igdkmd32.sys
*** ERROR: Module load completed but symbols could not be loaded for Ndu.sys
*** ERROR: Module load completed but symbols could not be loaded for wfplwfs.sys
*** ERROR: Module load completed but symbols could not be loaded for raspppoe.sys
*** ERROR: Module load completed but symbols could not be loaded for ndiswan.sys
*** ERROR: Module load completed but symbols could not be loaded for wanarp.sys
*** ERROR: Module load completed but symbols could not be loaded for tcpip.sys
*** WARNING: Unable to verify timestamp for RTL8192su.sys
*** ERROR: Module load completed but symbols could not be loaded for RTL8192su.sys
Probably caused by :[B]igdkmd32.sys ( igdkmd32+96fd0 )[/B]
BugCheck [B]1000007F, {8, 80d39000, 0, 0}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x1000007F"]UNEXPECTED_KERNEL_MODE_TRAP_M (1000007f)[/URL]
Arguments:
Arg1: 00000008, EXCEPTION_DOUBLE_FAULT
Arg2: 80d39000
Arg3: 00000000
Arg4: 00000000
BUGCHECK_STR:  0x7f_8
PROCESS_NAME:  System
FAILURE_BUCKET_ID: [B]0x7f_8_igdkmd32+96fd0[/B]
CPUID:        "Intel(R) Core(TM) i5-2450M CPU @ 2.50GHz"
MaxSpeed:     2500
CurrentSpeed: [B]2494[/B]
  BIOS Version                  A11
  BIOS Release Date             08/03/2012
  Manufacturer                  Dell Inc.
  Product Name                  Inspiron N5110
**************************Fri Jun 14 20:17:17.686 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\061513-14531-01.dmp]
System Uptime:[B]0 days 0:07:28.407[/B]
Probably caused by :[B]igdkmd32.sys ( igdkmd32+96fdc )[/B]
BugCheck [B]1000007F, {8, 81539000, 0, 0}[/B]
Arguments:
Arg2: 81539000
Arg3: 00000000
Arg4: 00000000
FAILURE_BUCKET_ID: [B]0x7f_8_igdkmd32+96fdc[/B]
MaxSpeed:     2500
  BIOS Version                  A11
**************************Fri Jun 14 20:09:20.172 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\061513-49859-01.dmp]
System Uptime:[B]0 days 3:36:02.005[/B]
Probably caused by :[B]igdkmd32.sys ( igdkmd32+3a7a9 )[/B]
BugCheck [B]1000007F, {8, 81618000, 0, 0}[/B]
Arguments:
Arg2: 81618000
Arg3: 00000000
Arg4: 00000000
FAILURE_BUCKET_ID: [B]0x7f_8_igdkmd32+3a7a9[/B]
MaxSpeed:     2500
  BIOS Version                  A11
**************************Fri Jun 14 15:16:19.139 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\061413-18187-01.dmp]
System Uptime:[B]0 days 0:37:06.860[/B]
Probably caused by :[B]igdkmd32.sys ( igdkmd32+971e0 )[/B]
BugCheck [B]1000007F, {8, 80838000, 0, 0}[/B]
Arguments:
Arg2: 80838000
Arg3: 00000000
Arg4: 00000000
FAILURE_BUCKET_ID: [B]0x7f_8_igdkmd32+971e0[/B]
MaxSpeed:     2500
  BIOS Version                  A11
[/FONT]
3rd Party Drivers:
[COLOR=RED][B]RTL8192su.sys               Mon May  9 05:07:39 2011 (4DC7AEDB)[/B][/COLOR]
[COLOR=RED][B]tixhci.sys                  Wed Jul 20 14:36:12 2011 (4E27201C)[/B][/COLOR]
[COLOR=RED][B]tihub3.sys                  Wed Jul 20 14:36:29 2011 (4E27202D)[/B][/COLOR]
[COLOR=RED][B]Rt630x86.sys                Wed Oct 19 08:13:13 2011 (4E9EBED9)[/B][/COLOR]
athr.sys                    Wed Mar 21 23:20:45 2012 (4F6A9A8D)
igdkmd32.sys                Fri May 25 00:21:42 2012 (4FBF08D6)
nvlddmkm.sys                Mon Jun 18 16:43:50 2012 (4FDF9306)
intelppm.sys                Wed Jul 25 22:34:02 2012 (5010AC9A)
dump_storahci.sys           Wed Jul 25 22:38:58 2012 (5010ADC2)
[/FONT]
http://www.carrona.org/drivers/driver.php?id=athr.sys
http://www.carrona.org/drivers/driver.php?id=igdkmd32.sys
http://www.carrona.org/drivers/driver.php?id=dump_storahci.sys
    Win8.1Pro - Finally!!!
    Samsung/NP780
    upgraded to 12 gB from 8 gB
    800x600
    no Mouse - Trackball!!!!
    Country Flag
    USA
    State/Region Flag
    us connecticut
