- Help - Extended monitor and laptop monitor not working
Wassouf
2
Hi,
Today I plugged an hdmi to vga cable into my Win 8 sony vaio, and I plugged the other VGA side of the cable into an acee 22" monitor. I then chose from the right hand windows 8 panel to "extend to monitor", the laptop screen went black, the monitor screen remained without signal (extended screen did not show on monitor) and now the laptop screen is black.
I am now stuck and both laptop and monitor screen not working.
I tried unplugging cable, pressing fn and all the f1 to f12, shift, windows button but nothing is working.
I pressed off button then switched laptop back on and it showed the sony vaio logo on laptop then the screen went black again.
Please tell me how could I return my laptop screen to work and stop the screen extension which is not working and which I am sure is the case.
Any buttons on keyboard to click at all?
Any solution is highly appreciated.
Thank you
W
    Win 8
XweAponX
It's stuck in an extended screen it seems, boot into Safe Mode while you have all external monitors unplugged - Your Display is probably set to a resolution too high for both the external monitor and the laptop monitor, so you'll have to try "Boot to VGA mode" and I don't know where that is in the Windows 8 Boot GUI, if it is even in there at all.
Here is is- There are several ways to get to that from the Boot screen:
http://www.eightforums.com/tutorials/4924-advanced-startup-settings-boot-windows-8-a.html
    AMD 4400+/4200+
    2 GB/3GB
    GeForce 8400 GS/GeForce 210
    Hitachi 40" LCD HDTV
    "1842 x 1036"
    WD My Book 1140 USB Device
    Works 550w
    MSI "M-Box"
    Water Cooled
    Dell Keyboard
    Microsoft Intellimouse
    Cable Medium Speed
    Chrome/IE 10
    Eset NOD32 6.x/Win Defend
