Help BSOD every 30 minutes or so
dtsm4ever
my computer keeps restarting with a blue screen and the error messages are different each time; I've attempted to wipe clean the windows and all data doing a fresh re installation but the same problem comes back 2-3 days after the re-installment. i tried looking for solutions online but i'm not very fluent in anything to do with computers so i'm hoping to get some help here. here are some diagnostics reports i got through what i managed to make sense of from other online resources hopefully it'll have the information you guys need for pointing me in the right direction to fix this problem.
thanks in advance!
EDIT: sorry i just noticed the rules for posting; here's the extra attachments required as per instructions from posting guidelines
Hi dtsm4ever & Welcome to the forums ^_^,
I have analysed your dump files and below has been provided an analysis of the same for informative purposes :-
**************************Sun Nov 23 05:50:27.480 2014 (UTC + 5:30)**************************
Loading Dump File [C:\SysnativeBSODApps\112214-23625-01.dmp]
Windows 8 Kernel Version 9600 MP (4 procs) Free x64
Built by: 9600.17328.amd64fre.winblue_r3.140827-1500
System Uptime: 0 days 0:07:28.211
Probably caused by : win32k.sys ( win32k!TimersProc+230 )
BugCheck A, {fffffffffffffff8, 2, 0, fffff8000b88ae74}
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x0000000A]IRQL_NOT_LESS_OR_EQUAL (a)[/url]
Arguments:
Arg1: fffffffffffffff8, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, bitfield :
 bit 0 : value 0 = read operation, 1 = write operation
 bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: fffff8000b88ae74, address which referenced memory
BUGCHECK_STR:  AV
PROCESS_NAME:  csrss.exe
FAILURE_BUCKET_ID:  AV_win32k!TimersProc
  BIOS Version                  2503
  BIOS Release Date             01/21/2010
  Manufacturer                  System manufacturer
  Product Name                  System Product Name
**************************Sun Nov 23 05:41:49.226 2014 (UTC + 5:30)**************************
Loading Dump File [C:\SysnativeBSODApps\112214-20578-01.dmp]
System Uptime: 0 days 22:41:25.975
*** ERROR: Module load completed but symbols could not be loaded for Ntfs.sys
*** ERROR: Module load completed but symbols could not be loaded for luafv.sys
*** WARNING: Unable to verify timestamp for aswSnx.sys
*** ERROR: Module load completed but symbols could not be loaded for aswSnx.sys
Probably caused by : Ntfs.sys ( Ntfs+3dc22 )
BugCheck 24, {b500190637, ffffd001f2644958, ffffd001f2644160, fffff80069c47c22}
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x00000024]NTFS_FILE_SYSTEM (24)[/url]
Arguments:
Arg1: 000000b500190637
Arg2: ffffd001f2644958
Arg3: ffffd001f2644160
Arg4: fffff80069c47c22
PROCESS_NAME:  TiWorker.exe
BUGCHECK_STR:  0x24
FAILURE_BUCKET_ID:  0x24_Ntfs+3dc22
  BIOS Version                  2503
**************************Fri Nov 21 14:59:56.450 2014 (UTC + 5:30)**************************
Loading Dump File [C:\SysnativeBSODApps\112114-16171-01.dmp]
System Uptime: 0 days 0:16:45.193
Probably caused by : ntkrnlmp.exe ( nt!KiFastFailDispatch+d0 )
BugCheck 139, {3, ffffd000fe06a890, ffffd000fe06a7e8, 0}
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x00000139]KERNEL_SECURITY_CHECK_FAILURE (139)[/url]
Arguments:
Arg1: 0000000000000003, A LIST_ENTRY has been corrupted (i.e. double remove).
Arg2: ffffd000fe06a890, Address of the trap frame for the exception that caused the bugcheck
Arg3: ffffd000fe06a7e8, Address of the exception record for the exception that caused the bugcheck
Arg4: 0000000000000000, Reserved
BUGCHECK_STR:  0x139
DEFAULT_BUCKET_ID:  LIST_ENTRY_CORRUPT
PROCESS_NAME:  chrome.exe
FAILURE_BUCKET_ID:  0x139_3_nt!KiFastFailDispatch
  BIOS Version                  2503
**************************Fri Nov 21 14:29:58.012 2014 (UTC + 5:30)**************************
Loading Dump File [C:\SysnativeBSODApps\112114-18640-01.dmp]
System Uptime: 0 days 7:44:30.755
Probably caused by : win32k.sys ( win32k!TimersProc+25a )
BugCheck 139, {3, ffffd00104f2e8a0, ffffd00104f2e7f8, 0}
Arguments:
Arg2: ffffd00104f2e8a0, Address of the trap frame for the exception that caused the bugcheck
Arg3: ffffd00104f2e7f8, Address of the exception record for the exception that caused the bugcheck
BUGCHECK_STR:  0x139
FAILURE_BUCKET_ID:  0x139_3_win32k!TimersProc
  BIOS Version                  2503
**************************Fri Nov 21 06:08:07.348 2014 (UTC + 5:30)**************************
Loading Dump File [C:\SysnativeBSODApps\112014-22312-01.dmp]
System Uptime: 0 days 11:18:23.092
BugCheck 139, {3, fffff800de5cbba0, fffff800de5cbaf8, 0}
Arguments:
Arg2: fffff800de5cbba0, Address of the trap frame for the exception that caused the bugcheck
Arg3: fffff800de5cbaf8, Address of the exception record for the exception that caused the bugcheck
BUGCHECK_STR:  0x139
PROCESS_NAME:  aswFe.exe
  BIOS Version                  2503
Below is the list of 3rd party drivers present on your system :-
L1E62x64.sys                Thu Sep 22 11:56:32 2011 (4E7AD518)
GEARAspiWDM.sys             Fri May  4 01:26:17 2012 (4FA2E2E1)
[B][U]ASACPI.sys                  Fri Nov  2 07:24:34 2012 (509327DA)
[/U][/B]AODDriver2.sys              Thu Sep 12 09:06:40 2013 (523136C8)
point64.sys                 Thu Dec 12 18:46:17 2013 (52A9B721)
[COLOR=#FF0000]avgtpx64.sys                Mon Jun 30 16:45:17 2014 (53B146C5)
[/COLOR]atikmpag.sys                Sat Jul  5 06:56:52 2014 (53B7545C)
atikmdag.sys                Sat Jul  5 07:09:13 2014 (53B75741)
[COLOR=#FF0000]VBoxAswDrv.sys              Wed Nov  5 17:28:43 2014 (545A10F3)
aswKbd.sys                  Thu Nov  6 18:23:07 2014 (545B6F33)
aswMonFlt.sys               Thu Nov  6 18:23:07 2014 (545B6F33)
aswRvrt.sys                 Thu Nov  6 18:23:22 2014 (545B6F42)
aswVmm.sys                  Thu Nov  6 18:23:31 2014 (545B6F4B)
aswRdr2.sys                 Thu Nov  6 18:24:02 2014 (545B6F6A)
aswHwid.sys                 Thu Nov  6 18:25:01 2014 (545B6FA5)
aswNdisFlt.sys              Thu Nov  6 18:25:50 2014 (545B6FD6)
aswSP.sys                   Thu Nov  6 18:39:55 2014 (545B7323)
aswStm.sys                  Thu Nov  6 18:41:00 2014 (545B7364)
aswSnx.sys                  Fri Nov 21 16:47:12 2014 (546F1F38)
[/COLOR]¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨``
aswSnx.sys                  Thu Nov  6 18:23:55 2014 (545B6F63)
VBoxDDR0.r0                 Mon Nov  3 21:17:51 2014 (5457A3A7)
VBoxDD2R0.r0                Mon Nov  3 21:17:53 2014 (5457A3A9)
VMMASWR0.r0                 Wed Nov  5 17:27:59 2014 (545A10C7)
http://www.carrona.org/drivers/driver.php?id=L1E62x64.sys
http://www.carrona.org/drivers/driver.php?id=GEARAspiWDM.sys
http://www.carrona.org/drivers/driver.php?id=ASACPI.sys
http://www.carrona.org/drivers/driver.php?id=AODDriver2.sys
http://www.carrona.org/drivers/driver.php?id=point64.sys
http://www.carrona.org/drivers/driver.php?id=avgtpx64.sys
VBoxAswDrv.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=aswKbd.sys
http://www.carrona.org/drivers/driver.php?id=aswMonFlt.sys
http://www.carrona.org/drivers/driver.php?id=aswRvrt.sys
http://www.carrona.org/drivers/driver.php?id=aswVmm.sys
http://www.carrona.org/drivers/driver.php?id=aswRdr2.sys
http://www.carrona.org/drivers/driver.php?id=aswHwid.sys
http://www.carrona.org/drivers/driver.php?id=aswNdisFlt.sys
http://www.carrona.org/drivers/driver.php?id=aswSP.sys
http://www.carrona.org/drivers/driver.php?id=aswStm.sys
http://www.carrona.org/drivers/driver.php?id=aswSnx.sys
http://www.carrona.org/drivers/driver.php?id=VBoxDDR0.r0
http://www.carrona.org/drivers/driver.php?id=VBoxDD2R0.r0
VMMASWR0.r0 - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
It seems that there is a part of AVG left from the previous installation. Till the time we are troubleshooting, kindly remove both Avast and AVG using the below Tools -
If you are still facing problems, kindly update the driver highlighted in Underline and BOLD. Also, kindly post back the result of the Hardware Diagnostics (Thanks usasma) over here -
Let me know how it goes ^_^
