Solved HD7870 Drivers and CCC - Please Help.
OzK
6
I managed to load the 12.3 drivers through the device manager but so far have had no luck in getting CCC to work. The only thing I really want to change is to disable the underscan on my monitors. If anyone could help me figure out either how to get CCC working or how to edit the registry to turn off the underscan it would be really appreciated.
Solution for anyone else with this problem.
just uninstall every thing for gpu then u can use 12.4 just install it with w7 compatibility mode and it work like charm
Booted into safe mode, ran driver sweeper, then did this. CCC now works and I can finally adjust graphics settings and get rid of the underscan. Thank you!
    Windows 8 Consumer Preview - 64 bit
Calico
828
    Windows 7 x64 Ultimate/Windows 8.1/Linux
    FX-8350
    GA-990XA-UD3
    16GB DDR3 Corsair Vengeance
    HD7860
    Xonar Essence STX
    Benq
    Various
    Corsair HX 850W
    Corsair Obsidian
    Thermalright
    Logitech
    Logitech
    firefox
OzK
6
Tried the first link already with no success. The post is from 2007 so not sure if its relevant. Will try the 12.4 driver and post back.
EDIT: The 12.4 driver works when installed through device manager but on CCC I only see the CPU stuff and HydraVision.
Calico
828
It used to be, the configuration for this was found under 'Desktop and Displays' where you should find an image of your TV. But with the later drivers, there's a section for configuring profiles under 'My Digital Flat Panels/HDTV'. Failing that, you could look at ATI Tray Tools I seem to remember it has some configuration settings for things like this...
    FX-8350
    GA-990XA-UD3
    HD7860
    Xonar Essence STX
    Benq
    Various
    Corsair HX 850W
    Corsair Obsidian
    Thermalright
    Logitech
    Logitech
    firefox
1,851
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\amdkmdag
TVEnableOverscan REG_DWORD
    P4 3.4 GHz HT
    MSI-7211
    OCZ 2 GB DDR @ 400 MHz
    HIS AGP HD 3850 Turbo Ice-Q
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
OzK
6
Tried changing this value from 1 to 0 and rebooted the PC didn't seem to have any effect.
Until AMD releases a consumer preview driver supporting 7800 series cards I think I may be out of luck. CCC and Tray Tools dont work.
1,851
Not out of luck. CCC 12.3 works fine. Install normally by running the .exe:
AMD Catalyst 12.3 WHQL 64-bit download from Guru3D.com
Tray Tools works fine too, but I don't see any setting for under/overscan. (Maybe only when connected to tv? I dunno.)
Use the non-Guru3d Driver Sweeper in safe mode first, if you're not having luck.
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
1,851
#9
Yeah, all options are in CCC.
Are you having a problem on your tv or monitor? If it's a monitor, make sure you have the correct native resolution for it set (its intended resolution by manufacturer) and if there is still a problem, use the buttons on the monitor itself to fix it.
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
OzK
6
#10
Monitor, tried messing with settings on monitor and no luck. If I uninstall the AMD driver and let it use windows basic display adapter it fills the whole screen but once I load the right drivers through the device manager I'm stuck with the underscan.
1,851
#11
That's not a driver or CCC issue. It sounds to me like you don't have the driver set to the monitor's designed-for resolution.
Right click the desktop | Screen resolution
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
yahyoh
22
#12
    windows 8.1 pro X64
    Acer 5740G
    Intel core i5 430m
    4 GB @ 1066 mhz
    Amd 5470m
OzK
6
#13
