Graphics card not plugged in warning?
TimeAndroid
101
Whenever I restart my computer I sometimes get in red letters a warning saying you have not plugged in your graphics card and a loud beeping sound. I already checked it and made sure it is fully plugged in, what's going on?
Also, only when restarting it occasionally gives me that warning. Other than that, its fine booting up, never gave me the error. Also if i get the error and press the reset button on the computer it'll do that until I force it to shutdown by holding the power button. And, my display works fine.
    Windows 8.1 64-bit
24,164
Hello Kyle,
You might try it connected in another slot to see if it may be an issue with the one it's currently in.
In addition, double check all 8-pin or 6-pin power connections on the card (if any) to make sure that they are securely connected at both ends.
Hope this helps, :)
    3 x 27" Asus VE278Q
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
Please Mark This Thread As Solved if the suggestion of brinks worked fine for you
Best Wishes,
Win8PcTech
    Windows 8 Pro
    Intel E6550
    Intel (R)Core2Duo(TM)2.33GhZ
    2.00 GB
    256 graphics memory
    Generic Non PnP Monitor
    1024 x 768 (32Bit) (60Hz)
    60 GB
    DELL
    Logitech Wireless Mouse
    100MBPS
    IE
    None
TimeAndroid
101
Hello Kyle,
Hope this helps, :)
Tried that and updated the BIOS. It seemed to work for a while but now it's doing that again.
    Windows 8.1 64-bit
24,164
Hmm, you might try a different PCI-E slot to see how it works in it.
    3 x 27" Asus VE278Q
    Logitech MX Master
    Lumia 1520 phone
