Greetings,
- Please copy & paste the following into notepad.
netsh wlan show all >%userprofile%\Desktop\Network.txt
sc query dhcp >>%userprofile%\Desktop\Network.txt
sc query dnscache >>%userprofile%\Desktop\Network.txt
sc query wlansvc >>%userprofile%\Desktop\Network.txt
ipconfig /all >>%userprofile%\Desktop\Network.txt
netsh advfirewall show global >>%userprofile%\Desktop\Network.txt
netsh winhttp show proxy >>%userprofile%\Desktop\Network.txt
- Save the file as "Network.bat"
- Right click the file and select Run as Administrator.
- This will create a file called "Network.txt" on the desktop.
- Copy & paste the contents into your next post.
Ok I connected to where it says limited connectivity to do this, and have already installed all needed updates. The following is the file you told me to copy and paste. Thanks:
Wireless System Information Summary
(Time: 12/24/2013 3:32:48 PM Eastern Standard Time)
============================== SHOW DRIVERS ===========================
Interface name: Wi-Fi
Driver : Broadcom 802.11n Network Adapter
Vendor : Broadcom
Provider : Broadcom
Date : 8/6/2013
Version : 6.30.223.143
INF file : C:\windows\INF\oem12.inf
Files : 4 total
C:\windows\system32\DRIVERS\BCMWL63a.SYS
C:\windows\system32\bcmihvsrv64.dll
C:\windows\system32\bcmihvui64.dll
C:\windows\system32\drivers\vwifibus.sys
Type : Native Wi-Fi Driver
Radio types supported : 802.11n 802.11g 802.11b
FIPS 140-2 mode supported : Yes
802.11w Management Frame Protection supported : Yes
Hosted network supported : Yes
Authentication and cipher supported in infrastructure mode:
Open None
Open WEP
WPA2-Enterprise TKIP
WPA2-Personal TKIP
WPA2-Enterprise CCMP
WPA2-Personal CCMP
WPA-Enterprise TKIP
WPA-Personal TKIP
WPA-Enterprise CCMP
WPA-Personal CCMP
Authentication and cipher supported in ad-hoc mode:
WPA2-Personal CCMP
Open None
Open WEP
IHV service present : Yes
IHV adapter OUI : [00 10 18], type: [00]
IHV extensibility DLL path: C:\windows\System32\bcmihvsrv64.dll
IHV UI extensibility ClSID: {aaa6dee9-31b9-4f18-ab39-82ef9b06eb73}
IHV diagnostics CLSID : {00000000-0000-0000-0000-000000000000}
============================= SHOW INTERFACES =========================
There is 1 interface on the system:
Description : Broadcom 802.11n Network Adapter
GUID : b337d9c4-b936-4e77-a138-cba3fcef233c
Physical address : 80:56:f2:35:69:b6
State : connected
SSID : Nacho Internet
BSSID : 00:90:a9:ae:18:8b
Network type : Infrastructure
Radio type : 802.11n
Authentication : WPA2-Personal
Cipher : CCMP
Connection mode : Auto Connect
Channel : 11
Receive rate (Mbps) : 72
Transmit rate (Mbps) : 72
Signal : 97%
Profile : Nacho Internet
Hosted network status : Not available
=========================== SHOW HOSTED NETWORK =======================
Hosted network settings
Mode : Allowed
Settings : <Not configured>
Status : Not available
============================= SHOW SETTINGS ===========================
Wireless LAN settings
Show blocked networks in visible network list: No
Only use GP profiles on GP-configured networks: No
Hosted network mode allowed in WLAN service: Yes
Allow shared user credentials for network authentication: Yes
Block period: Not Configured.
Auto configuration logic is enabled on interface "Wi-Fi"
============================== SHOW FILTERS ===========================
Allow list on the system (group policy)
<None>
Allow list on the system (user)
<None>
Block list on the system (group policy)
<None>
Block list on the system (user)
<None>
=========================== SHOW CREATEALLUSER ========================
Everyone is allowed to create all user profiles.
============================= SHOW PROFILES ===========================
Profiles on interface Wi-Fi:
Group policy profiles (read only)
<None>
User profiles
All User Profile : Nacho Internet
========================== SHOW PROFILES NAME=* =======================
Profile Nacho Internet on interface Wi-Fi:
Applied: All User Profile
Profile information
Version : 1
Type : Wireless LAN
Control options :
Connection mode : Connect automatically
Network broadcast : Connect only if this network is broadcasting
AutoSwitch : Do not switch to other networks
Connectivity settings
Number of SSIDs : 1
SSID name : "Nacho Internet"
Radio type : [ Any Radio Type ]
Vendor extension : Not present
Security settings
Cipher : CCMP
FIPS mode : Disabled
Security key : Present
Cost settings
Cost : Unrestricted
Congested : No
Approaching Data Limit : No
Over Data Limit : No
Roaming : No
Cost Source : Default
======================= SHOW NETWORKS MODE=BSSID ======================
Interface name : Wi-Fi
There are 5 networks currently visible.
SSID 1 : ATT3Y2P9i4
Encryption : CCMP
BSSID 1 : b0:77:ac:c9:67:40
Signal : 81%
Channel : 1
Basic rates (Mbps) : 1 2 5.5 11
Other rates (Mbps) : 6 9 12 18 24 36 48 54
SSID 2 : 2WIRE527
Authentication : WPA-Personal
Encryption : TKIP
BSSID 1 : 34:ef:44:4b:ed:51
Signal : 32%
Radio type : 802.11g
Channel : 6
SSID 3 : NETGEAR
Authentication : Open
Encryption : None
BSSID 1 : 00:1e:2a:e3:36:4d
Signal : 28%
Channel : 6
SSID 4 : 2WIRE416
Encryption : CCMP
BSSID 1 : 3c:ea:4f:a6:d2:d1
Signal : 12%
Channel : 9
SSID 5 : Nacho Internet
Encryption : CCMP
BSSID 1 : 00:90:a9:ae:18:8b
Signal : 100%
Channel : 11
Basic rates (Mbps) : 1 2 5.5 6 11 12 24
Other rates (Mbps) : 9 18 36 48 54
SERVICE_NAME: dhcp
TYPE : 20 WIN32_SHARE_PROCESS
STATE : 4 RUNNING
(STOPPABLE, NOT_PAUSABLE, ACCEPTS_SHUTDOWN)
WIN32_EXIT_CODE : 0 (0x0)
SERVICE_EXIT_CODE : 0 (0x0)
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: dnscache
STATE : 4 RUNNING
(STOPPABLE, NOT_PAUSABLE, IGNORES_SHUTDOWN)
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: wlansvc
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
Windows IP Configuration
Host Name . . . . . . . . . . . . : Leeandra
Wireless LAN adapter Wi-Fi:
Description . . . . . . . . . . . : Broadcom 802.11n Network Adapter
Physical Address. . . . . . . . . : 80-56-F2-35-69-B6
Link-local IPv6 Address . . . . . : fe80::184f:b69:99c0:d5f9%4(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.112(Preferred)
Lease Obtained. . . . . . . . . . : Tuesday, December 24, 2013 3:30:39 PM
Lease Expires . . . . . . . . . . : Tuesday, December 31, 2013 3:30:40 PM
Default Gateway . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 75519730
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-19-F3-1F-C5-20-1A-06-2C-27-4C
DNS Servers . . . . . . . . . . . : 192.168.1.1
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . : hsd1.mi.comcast.net.
Description . . . . . . . . . . . : Qualcomm Atheros AR8172/8176/8178 PCI-E Fast Ethernet Controller (NDIS 6.30)
Physical Address. . . . . . . . . : 20-1A-06-2C-27-4C
Tunnel adapter isatap.{B337D9C4-B936-4E77-A138-CBA3FCEF233C}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3
Global Settings:
IPsec:
StrongCRLCheck 0
isabled
SAIdleTimeMin 5min
DefaultExemptions NeighborDiscovery,DHCP
IPsecThroughNAT Never
AuthzUserGrp None
AuthzComputerGrp None
AuthzUserGrpTransport None
AuthzComputerGrpTransport None
StatefulFTP Enable
StatefulPPTP Enable
Main Mode:
KeyLifetime 480min,0sess
SecMethods DHGroup2-AES128-SHA1,DHGroup2-3DES-SHA1
ForceDH No
Categories:
BootTimeRuleCategory McAfee Personal Firewall
FirewallRuleCategory McAfee Personal Firewall
StealthRuleCategory Windows Firewall
ConSecRuleCategory Windows Firewall
Ok.
Current WinHTTP proxy settings:
Direct access (no proxy server).
