Fix Built in Flash Player?
qwetymikey
Hi,
last week I noticed chrome wasnt displaying both flash files in chrome://plugins/ and because I was having problems even after reinstalling flash several times, I started deleting folders and started playing with the registry :(
I finally was able to install flash and it works on chrome and firefox, but now I just noticed that it is not working on IE 10 ... it keeps asking me to install it and when I go here Flash Player Help | Flash Player Help and click on check now i get
YOUR SYSTEM INFORMATION
Your Flash VersionFlash Player disabled
Your browser nameInternet Explorer
Your Operating System (OS)Windows (Windows 8)
How can i reinstall the built in flash player?? I think me playing with the registry is the cause of this.
    Windows 8 Pro
    I7 3770
antspants
I'm on a Horse ...
I don't know about ie10 but chrome updates flash player on its own without interaction from the end user.
You probably know what you're doing so I wont tell you to check IE addons
Check that this hasn't been inadvertently enabled?
Disable Flash in IE10
Also, just for look sake, check if your monitor has any device driver updates. May or may not help.
Also
1. Internet Explorer> Tools (or Alt + t)> Manage add-ons (Show: All add-ons) verify that the Shockwave Flash Objects are enabled.
2. From Safety on the IE Command Bar (you may have to right-click the IE toolbar and enable the Command Bar) uncheck ActiveX Filtering.
If that helps, it would be safer to re-enable ActiveX Filtering and make an exception for the affected sites.
See this article:
How to use Tracking Protection and ActiveX Filtering:
http://windows.microsoft.com/en-US/windows7/How-to-use-Tracking-Protection-and-ActiveX-Filtering
Also
Enabling Flash Player in Internet Explorer
ActiveX Filtering in Internet Explorer
I don't use IE really but I did come accross this which isnt really related to your issue but interesting
Flash Player Security with Windows 8 and Internet Explorer 10
I hope something in all that helps, I obviously have no quick answer sorry.
    Windows 8.1 x64
    0i812
    Intel Core i7 4770K LGA1150
    Asus Maximus VI Formula
    Corsair 32GB (4x8GB) DDR3 CMY32GX3M4A1866C9 1866MH
    2 x Crappy GeForce GT 640 2GB DDR3
    I haz lollies ..
    2 x LG / 2 x Samsung 21 Inch
    Crispy
    2 x Samsung 250GB SSD 840 EVO (OS / Other)
    1 x Kingston 120G HyperX SSD (Swap)
    3 x Seagate SATA III 2TB Barracuda (Data Drives)
    1 x Seagate SATA III 1TB Barracuda (Media to XBox)
    1 x W/Digital SATA II 300G VelociRaptor (Image)
    Silverstone 1500w
    NZXT Phantom 820 White Full Tower
    Noctua NH-D14
    Logitech G19
    Logitech G700 / Logitech T650 Touchpad Thingy
    ADSL 2+ (Australian version ... lol)
    All of them
    Nortons IS
    This one time at band camp ...
