Ext HDD sponateously uninitialized itself. Possible fix?
DNW
My Western digital mybook 3TB ext HDD was functioning fine without issue. I woke up one day to find that the drive had disappeared from windows explorer and only appeared as "mass storage device" in the device manager. When I list the drives in the command prompt, it appears as online, but has 0B total space. In the disk manager the only info - or lack thereof - is "unknown" and "not initialized". There is no info regarding its volume (see pictures).
I did get a little fed up with it and decided to initialize the disk and start over, but I was met with an error that read something like " cannot initialize due to I/O device error" (see picture again). It seems like my computer acknowledges that there is a blank disk with 0B total space.
I tried to plug the drive into my computer and boot using ubuntu 14.10 live to see if my disk could be read in that OS, but the drive was nowhere to be found.
The drive contains data that I would really like to retrieve, so I am racking my brain trying to figure this out. The only other case I could find similar to mine is here: Previously functional USB3 external hard drive shows not initialized - Windows 7 Help Forums
All other search results seem to show people having issues with 'like-new' drives (meaning that there is info about the drive in disk manager prior to initialization), so I'm afraid I can't find many sources for comparison to help with this. I have posted about this elsewhere: External HDD uninitialized on its own. Can I recover data? - Tech & Computer Forums.
I would like to try every possible fix before resorting to disassembling the drive enclosure and putting the HDD inside my computer. Thank you for reading, and all input is very appreciated!
Sounds like the external drive interface is toast, hopefully not the drive. May have no other choice than remove it from the external case and try in another USB caddy or drive bay.
    Windows 8.1 Pro 64-bit
    Acer V3 771G-6443
    i5-3230m
    Acer VA70_HC (U3E1)
    8GB DDR3 PC3-12800 (800 MHz)
    HD4000 + GeForce GT 730M
    Realtek High Definition Audio
    1600x900 pixels
    Samsung SSD 850 EVO 250 GB
    ADATA SSD SP900 128GB
    90 watt brick
    Bluetooth
    Comodo
A lot of people are having issues with the MyBooks. I would contact Western Digital and see if they will replace the drive. If you are going to try and recover any items on it. Try booting up with a Linux LiveDVD and see if the drive shows up when you plug it in. Then you may be able to move the files from the MyBook, to another drive.
    Linux Mint 17.2
    12GB
    AMD Radeon™ HD 7310 Graphics
    Realtek HD
    LCD
    1366 x 768
    Crucial M500 240GB SSD
    Logitech M525
    45/6 - ATT U-Verse
    None needed. It is Linux.
Thanks for the input. WD customer support was unhelpful in offering a solution. Maybe I'll call back and ask for a replacement drive.
I tried booting up with ubuntu 14.10 but the drive was nowhere to be found.
Then the drive is toast.
    Linux Mint 17.2
    12GB
    Realtek HD
    LCD
    1366 x 768
    Logitech M525
    45/6 - ATT U-Verse
I bought the very same HD couple of years ago from COSCO, only one day when I plugged in, the disk became RAW/Unknown. I finally opened the enclosure and connected directly to the internal sata port and found out the disk was indeed having bad sectors. However, I was able to retrieve most of the data from it (mostly just Movies), returned back to COSCO without question asked.
Since the disk was going bad and apparently the USB interface in the enclosure did not know how to deal with it or toast and let's hope that's what happened to yours.
FYI, External HD is only designed for back up purpose and even that, it's not reliable. For sure It is not for constant use. The heat generated inside the enclosure is way, way too hot and there's no room for heat to dissipate and if you touch it, it is burning hot. The ideal temperature for HD is <= 42 C. All my internal HD's are almost 6 year old and have the fans blowing directly to them, make a little noise but keep the HD's temp to around 30C and they are all good.
    Home Brewed
    I7 4970K OC'ed @4.7 GHz
    MSI-Z97
    NVIDIA GeForce GTS 450
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    Logitech Performance Mouse MX
    35/12mbps
What you can try is removing the drive from the case, connecting it to your PC, and running Recuva to see if it finds the drive. IF it does, you might be able to recover some files and folders from the drive.
That said, "I/O error" is a bad sign and when I've encountered that, it means the drive has had a hardware failure -- and in that case, only disassembly and repair by a commercial data recovery outfit will get the drive working again.
