Solved Ethernet and Wireless
daniellouwrens
214
Hi
My W8 PC is connected to the Wireless Router by Ethernet Cable, the PC also
has Wireless connectivity; is it possible to connect to the Router with both at t
he same time and if I do will that improve internet speed?
Thanks
Daniel
    Windows 8.1 x64 with 8.1 Update
    Asus
    Intel(R) Core(TM) i5-3450 CPU @ 3.10GHz
    Asus
    8Gig
    Poor
    Asus
CountMike
Belgrade , Serbia
4,664
Your internet speed is determined by your provider and the package you have, it is irrelevant how fast your connection to router is as long as it is at least a little faster than speed to the provider. So you can not change the internet speed above what provider gives you.
    Home made
    AMD FX 6350Be @4.8GHz
    Gigabyte GA-990XA-UD3
    8GB Kingston 1866
    MSI AMD R7 260 oc
    Silicon Power V70 240GB SSD
    Kingston V300 120GB SSD
    WD 750GB Green
    WD 500GB black
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    CM Dragon Tower
    CCM Nepton 140xl
    10/2 Mbps
    WD
daniellouwrens
214
Hi
thanks for your help.
Cheers
Daniel
    Asus
    Asus
    8Gig
    Poor
    Asus
