GMan
Banned
You're finding it annoying, but in reality, you've successfully repaired a drastic problem with your machine; the worst problem there can possibly be, apart from faulty hardware:
So congrats on that!
As for your needing a reboot issue: You need to set the device manager properties for it to disallow Windows to turn off to save power. Right click it | Properties | Power Management tab
Also, check your power options settings.
Another good thing to do is check on anything in the bios that might shut it off.
Now, I do not get the "Driver_Power_State_Failure" error message.
- 8250 x86 + 7 SP1 x86 + Ubuntu 12.04 LTS x86
- CPU
- P4 3.4 GHz HT
- Motherboard
- MSI-7211
- Memory
- OCZ 2 GB DDR @ 400 MHz
- Graphics Card(s)
- HIS AGP HD 3850 Turbo Ice-Q
- Sound Card
- MOTU Traveler firewire interface
- Monitor(s) Displays
- Acer x223w
- Screen Resolution
- 1680x1050
- Hard Drives
- WD Caviar Black 1 TB Sata II, WD 400 GB Sata I, WD 120 GB Sata I
- PSU
- 300W generic
- Case
- Cybertron
- Keyboard
- Logitech Classic Keyboard 200, Dell RT7D20
- Mouse
- Logitech M510
- Internet Speed
- 2 MByte/sec Down, 250 KByte/sec Up
