Driver power state failure after resuming from sleep mode
Lan1
7
I'm having a BSOD problem. After walking computer from sleep mode, within 1-2 minutes it will get a BSOD with the "driver power state failure" error and restart, but interestingly I never get the error the moment I wake up the computer. I'm using a Lenovo IdeaPad Y510P with Windows 8.1 64-bit. I already tried uninstalling the Intel HD 4000 driver, restarting computer, and installing the one on Lenovo's site (as this was suggested on the Lenovo forum as a common fix) but it didn't help. The problem only started occurring after one of the following:
- Updating Malwarebytes to latest last week
- Installing a Windows update last week (there were 3 installed components, 1 of them was an Intel HD 4000 driver update, forgot what the other 2 were)
- Updating GeForce Experience and latest NVIDIA Graphics Driver (337.88), it included NVIDIA PhysX System Software 9.13.1220
Here is a log created by WinDbg tool: 'BSOD dump' | TextUploader.com
Here is a log created by BluescreenView:
Dump File : 060514-96281-01.dmp
Crash Time : 6/5/2014 7:23:39 PM
Bug Check String : DRIVER_POWER_STATE_FAILURE
Bug Check Code : 0x0000009f
Parameter 1 : 00000000`00000003
Parameter 2 : ffffe001`218f88e0
Parameter 3 : ffffd000`bff2b930
Parameter 4 : ffffe001`2561d1c0
Caused By Driver : ntoskrnl.exe
Caused By Address : ntoskrnl.exe+153fa0
File Description :
Product Name :
Company :
File Version :
Processor : x64
Crash Address : ntoskrnl.exe+153fa0
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\060514-96281-01.dmp
Processors Count : 8
Major Version : 15
Minor Version : 9600
Dump File Size : 1,271,704
Dump File Time : 6/5/2014 7:26:13 PM
The full minidump .dmp file is attached. In case attachments don't work here is the full minidump .dmp file uploaded: https://www.mediafire.com/?uv33hc3ffzdg8xb
Thanks for any help.
blueelvis
OMG Debugger!
India
2,097
Hi Lan1 and welcome to the forums ^_^,
I have analyzed your Dump file and below has been provided an analysis of your dump file for informative purposes :-
2: kd> !analyze -v*******************************************************************************
DRIVER_POWER_STATE_FAILURE (9f)
A driver has failed to complete a power IRP within a specific time.
Arguments:
Arg2: ffffe00135b5c060, Physical Device Object of the stack
Arg3: ffffd000c3df9930, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the Functional Device Object of the stack
Arg4: ffffe0013217d880, The blocked IRP
Debugging Details:
DRVPOWERSTATE_SUBCODE:  3
DRIVER_OBJECT: ffffe00135b70c30
IMAGE_NAME:  usbccgp.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  52678625
MODULE_NAME: usbccgp
FAULTING_MODULE: fffff80157d82000 usbccgp
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x9F
PROCESS_NAME:  System
CURRENT_IRQL:  2
ANALYSIS_VERSION: 6.3.9600.16384 (debuggers(dbg).130821-1623) amd64fre
STACK_TEXT:
ffffd000`c3df98f8 fffff801`31803c1e : 00000000`0000009f 00000000`00000003 ffffe001`35b5c060 ffffd000`c3df9930 : nt!KeBugCheckEx
ffffd000`c3df9900 fffff801`31803b3e : ffffe001`32f70320 ffffe000`ffffffff 00000000`00000000 fffff801`31664240 : nt!PopIrpWatchdogBugcheck+0xde
ffffd000`c3df9960 fffff801`31660810 : 00000000`00000000 ffffd000`c3df9ab0 ffffe001`32f70358 fffff801`317e1e24 : nt!PopIrpWatchdog+0x32
ffffd000`c3df99b0 fffff801`3175eaea : ffffd000`c8800180 ffffd000`c8800180 ffffd000`c880c3c0 ffffe001`32b9c080 : nt!KiRetireDpcList+0x4f0
ffffd000`c3df9c60 00000000`00000000 : ffffd000`c3dfa000 ffffd000`c3df4000 00000000`00000000 00000000`00000000 : nt!KiIdleLoop+0x5a
STACK_COMMAND:  kb
FOLLOWUP_NAME:  MachineOwner
IMAGE_VERSION:  6.3.9600.16442
FAILURE_BUCKET_ID:  0x9F_3_POWER_DOWN_IMAGE_usbccgp.sys
ANALYSIS_SOURCE:  KM
FAILURE_ID_HASH_STRING:  km:0x9f_3_power_down_image_usbccgp.sys
FAILURE_ID_HASH:  {447d6c25-e30e-cab7-b8c4-6eeb621d3df1}
Followup: MachineOwner
If we run an !irp on the 4th parameter, we get the usbccgp.sys and a reference to KSTHUNK which is the Kernel Streaming WOW64 Thunk Service of Windows
I remember this same kind of case. This KSTHUNK is associated with your Lenovo Easy Camera Software. So, please uninstall Lenovo Easy Camera and this should resolve your issue. (Fingers Crossed ^_^ )
In case the issue is solved, please mark this thread as solved ^_^
    Windows 8.1 Industry Pro B-)
    Toshiba
    Core I5 2430M @ 2.4GHz
    Intel HD 3000 B-)
    1366x768
    Toshiba 500 GB
blueelvis
OMG Debugger!
India
2,097
Thanks for the reply.
It actually stopped crashing for a few days, but today it gave the BSOD again, and since I didn't install anything over the last few days, the period of no crashes might have just been luck.
Attached is today's minidump.
Link: https://www.mediafire.com/?bf5ga8j7k90bpqt
Thanks.
Hi Lan1,
I have analyzed your latest Dump file and it is returning the same error that is, the Driver_Power_State_Failure and there is the presence of KSTHUNK as well. Did you remove the Lenovo Easy Camera from Control Panel's Add/Remove Programs?
Also, please follow this post in case the problem is still not solved as I would require the complete diagnostic info of your system :-
http://www.eightforums.com/bsod-cra...e-screen-death-bsod-posting-instructions.html
    Toshiba
    Intel HD 3000 B-)
    1366x768
    Toshiba 500 GB
Lan1
7
I used RevoUninstaller to uninstall Lenovo Easy Cam to make sure it clears everything associated with the program, not sure why it's saying it's still installed...
I checked the program list there's another program called "Lenovo YouCam" that's still installed, is that relevant?
Attached are the logs from the SF Diagnostics.
Thank you very much.
blueelvis
OMG Debugger!
India
2,097
#8
Hi Lan1,
Yeah please uninstall any lenovo software related to the webcam and see if the issue still persists or not. I guess that software is also using the same faulty module which is present in the lenovo easy camera. Please let me know if you still face problem.
    Toshiba
    Intel HD 3000 B-)
    1366x768
    Toshiba 500 GB
