Hi there
I don't know anyone whose actually run out of 26 Letters (English alphabet) for Disk drives yet.
You can always mount network drives anyway you want -- and then just set the Mount network drive option to be available at next boot
So if you want your drive can be mounted as
\\really\idiotic\drive if you want.
I can't see the normal user wanting to go through the Linux type of rigmarole in mounting directories etc -- yes of course its more flexible but there's IMO nothing wrong with having a simple letter as aMount point.
Shared network directories and libraries can give you alternate choices too.
Cheers
jimbo
Hi, Jimbo, it's not
"someone" running out of drive letters, it's
Windows running out of drive letters!
First, an analogy: I can open my documents folder, search all my documents for word files containing the words "Solicitor" and "Bank" and when the search has finished, I can select all the documents found, select them all, and open the lot in word by right clicking them and choosing open.
I think you would consider that fair use.
Now for my point:
Yesterday I tried an experiment, and searched my external drive for *.iso files. In the search window, there were 36 iso files there, all downloaded images of CDs or DVDs.
I can select one of the ISO images and open it, and Windows creates a new Virtual CD-ROM with that image loaded.
I can select 6 of the ISOs and Windows 8 creates 6 new Virtual CD-ROMs with those loaded images.
I select all of those 36 ISO files, and attempt to open them, and I get an error, not because my computer runs out of resources, but because Windows has run out of drive letters.
I consider that is a bug, a hopelessly dinosaurian feature, a limitation of Windows that should be corrected, in the same way that 8+3 file name lengths was corrected in Windows 95. I don't care for the arguments that "26 should be enough", any more than "640KB should be enough memory for anybody"
Windows 8 is a paradigm shifter - like Windows 95 was - this surely is the Windows version to get rid of the C: drive and its companions for good.
