hello
since i've solved almost all my problems that i had i wanted to listen to some music using laptop as a bluetooth headset for mobile
it worked but i noticed that internet speed using wifi gone slower is that normal ?
No. Why should it? Something else is going on, if you Internet speed went down. Most likely your WiFi card, which also does Bluetooth, is needing a little tweaking.
What is the manufacturer & model of the laptop, along with the wifi & bluetooth chipset info.
