chev65
Closed
- Location
- Beach house paradise
Thanks, some noticeable speed increases. Also waiting for a new router in the mail, hopefully that helps too.
If you check the InSSIDer you should notice that the new channel is mostly outside the channel overlap area. You had a very strong signal from a neighbor that was right on top of the channel you were using.
You could even use the old router as a wireless access point or install updated firmware which can fix all sorts of problems.
Have you tested long enough to determine if the problem is fixed or not?
- Windows 8.1 Pro WMC
- Computer type
- PC/Desktop
- System Manufacturer/Model
- Home built
- CPU
- Q9650 @ 4.05 GHz
- Motherboard
- Gforce 780i SLI FTW
- Memory
- 8GB Gskill DDR2 1200Mhz
- Graphics Card(s)
- GTX-480
- Sound Card
- Asus D2 Xonar
- Monitor(s) Displays
- HannsG
- Screen Resolution
- 1680x1050
- Hard Drives
- Gskill 120GB SSD
- PSU
- Thermal Take 1000watts
- Case
- Thermal Take Xtreme
- Cooling
- 9 fans air cooled
- Keyboard
- G15 logitech
- Mouse
- G9 logitech
- Internet Speed
- 50mbps
