milindsmart
I have a Desktop and a Laptop, both wirelessly connected to a router, and part of a HomeGroup. Sharing over HomeGroup works like a breeze. Occasionally I need to copy something large between the 2, so I connect an Ethernet cable.
To actually transfer the files, currently I have to :
I hate this process with a passion, because I have to do it every time. I have no clue how or why Windows decides a particular network to be "Identified" or "Unidentified". I would like some way of forcing Windows to treat all PC-to-PC connections as private (this arrangement is obviously VERY private, about as private as it gets), so that sharing is enabled, and so that it is recognized as a part of the HomeGroup, and then if I change the order of preference to Ethernet > WiFi, I should be able to have it automatically transfer over WiFi+Ethernet, just WiFi, or just Ethernet depending on which link is up....
One can dream
But still, any improvement over this process will be welcome.
- disconnect wifi from both, else step 3 won't work
- assign 192.0.0.0/24 addresses to each of them, setting no gateway
- try to browse the network, upon which I can force the conversion of network type to private
- upon which I might still have to manually type in the IP address in UNC format (\\192.168.1.3\)
- I have to authenticate as my user account on the other machine
- Then I have to share the required folders... Sometimes "pulling" the files doesn't work, upon which I have to assign write permissions onto a folder on the destination computer and "push" the files. Ugliest thing I have encountered.
One can dream
