Solved Computer does not recognize input or output
Christiansquare
For about 4 months my PC has been telling me that no speakers or headphones are plugged in even though i have connected speakers or headphones (Tried both). It also does not recognize my microphone when i connect it. I have updated my audio drivers several times with no success.I have tried both the front ,and back sockets and neither would work. I have recently installed windows 10 thinking that would help but the audio is exactly the same. At the moment i am using a USB headset and that is the only way i can have sound maybe because it uses a separate driver.But any way i want to be able to use my speakers and my good headphones again. This is a huge deal for me as i produce music and i want to be able to hear sound.
First you need, at a minimum Windows 8.1 sound drivers. However, as it didn't work in Win 8.1, and upgrading didn't help it may take a full "clean" install of the OS.
Without getting deep into troubleshooting, we have a sister Windows 10 forum and as this is a Windows 10 problem (now since 10 is installed) we ask that you post on the ten forum www.tenforums.,com
Have you tried Troubleshooting ?
Thanks for..... trying, but i found out it is a hardware problem and not windows so i will mark this as solved as the problem has nothing to do with windows.
