Can't connect to this network (wifi problems)
2
I have the same problem here
that's My "Network.txt" data:
Wireless System Information Summary
(Time: 17/10/2014 05:01:45 ê Egypt Standard Time)
============================== SHOW DRIVERS ===========================
Interface name: Wi-Fi
    Driver                    : RT73 USB Wireless LAN Card
    Vendor                    : Ralink Technology Corp.
    Provider                  : Microsoft
    Date                      : 30/09/2011
    Version                   : 4.0.10.0
    INF file                  : C:\Windows\INF\netr7364.inf
    Files                     : 2 total
                                C:\Windows\system32\DRIVERS\netr7364.sys
                                C:\Windows\system32\drivers\vwifibus.sys
    Type                      : Native Wi-Fi Driver
    Radio types supported     : 802.11b 802.11g
    FIPS 140-2 mode supported : Yes
    802.11w Management Frame Protection supported : No
    Hosted network supported  : Yes
    Authentication and cipher supported in infrastructure mode:
                                Open            None
                                Open            WEP-40bit
                                Open            WEP-104bit
                                Open            WEP
                                WPA-Enterprise  TKIP
                                WPA-Enterprise  CCMP
                                WPA-Personal    TKIP
                                WPA-Personal    CCMP
                                WPA2-Enterprise TKIP
                                WPA2-Enterprise CCMP
                                WPA2-Personal   TKIP
                                WPA2-Personal   CCMP
    Authentication and cipher supported in ad-hoc mode:
                                Open            None
                                Open            WEP-40bit
                                Open            WEP-104bit
                                Open            WEP
                                WPA2-Personal   CCMP
============================= SHOW INTERFACES =========================
There is 1 interface on the system:
    Description            : RT73 USB Wireless LAN Card
    GUID                   : 1cabb530-0686-44aa-9b8f-bcd5bdaebe99
    Physical address       : 00:25:86:eb:55:82
    State                  : disconnected
    Hosted network status  : Not available
=========================== SHOW HOSTED NETWORK =======================
Hosted network settings
    Mode                   : Allowed
    Settings               : <Not configured>
    Status                 : Not available
============================= SHOW SETTINGS ===========================
Wireless LAN settings
    Show blocked networks in visible network list: No
    Only use GP profiles on GP-configured networks: No
    Hosted network mode allowed in WLAN service: Yes
    Allow shared user credentials for network authentication: Yes
    Block period: Not Configured.
    Auto configuration logic is enabled on interface "Wi-Fi"
============================== SHOW FILTERS ===========================
Allow list on the system (group policy)
    <None>
Allow list on the system (user)
    <None>
Block list on the system (group policy)
    <None>
Block list on the system (user)
    <None>
=========================== SHOW CREATEALLUSER ========================
Everyone is allowed to create all user profiles.
============================= SHOW PROFILES ===========================
Profiles on interface Wi-Fi:
Group policy profiles (read only)
    <None>
User profiles
    All User Profile     : Yasser - 0123873183
    All User Profile     : UnConstitutional
========================== SHOW PROFILES NAME=* =======================
Profile Yasser - 0123873183 on interface Wi-Fi:
Applied: All User Profile
Profile information
    Version                : 1
    Type                   : Wireless LAN
    Name                   : Yasser - 0123873183
    Control options        :
        Connection mode    : Connect manually
        Network broadcast  : Connect only if this network is broadcasting
        AutoSwitch         : Do not switch to other networks
Connectivity settings
    Number of SSIDs        : 1
    SSID name              : "Yasser - 0123873183"
    Network type           : Infrastructure
    Radio type             : [ Any Radio Type ]
    Vendor extension          : Not present
Security settings
    Authentication         : Open
    Cipher                 : None
    Security key           : Absent
    Key Index              : 1
Cost settings
    Cost                   : Unrestricted
    Congested              : No
    Approaching Data Limit : No
    Over Data Limit        : No
    Roaming                : No
    Cost Source            : Default
Profile UnConstitutional on interface Wi-Fi:
Profile information
    Version                : 1
    Type                   : Wireless LAN
    Control options        :
        Connection mode    : Connect automatically
    Number of SSIDs        : 1
    SSID name              : "UnConstitutional"
Security settings
    Authentication         : WPA-Personal
    Cipher                 : TKIP
    Security key           : Present
Cost settings
    Cost                   : Unrestricted
    Congested              : No
    Roaming                : No
======================= SHOW NETWORKS MODE=BSSID ======================
Interface name : Wi-Fi
There are 4 networks currently visible.
SSID 1 : SAMATY
    Encryption              : TKIP
    BSSID 1                 : 4c:ed:de:d4:6c:8c
         Signal             : 50%
         Radio type         : 802.11g
         Channel            : 1
         Basic rates (Mbps) : 1 2 5.5 11
         Other rates (Mbps) : 6 9 12 18 24 36 48 54
SSID 2 : Vodafone_ADSL_9A60
    Authentication          : WPA2-Personal
    Encryption              : TKIP
    BSSID 1                 : 00:e0:4d:b9:9a:60
         Signal             : 15%
         Channel            : 11
SSID 3 : TE-Data
    Encryption              : TKIP
    BSSID 1                 : e8:39:df:30:f9:e5
         Signal             : 10%
         Channel            : 11
SSID 4 : LINKDSL-UnConstitutional
    Encryption              : CCMP
    BSSID 1                 : e4:77:23:ad:a9:18
         Signal             : 100%
         Radio type         : 802.11n
         Channel            : 13
SERVICE_NAME: dhcp
        TYPE               : 20  WIN32_SHARE_PROCESS
        STATE              : 4  RUNNING
                                (STOPPABLE, NOT_PAUSABLE, ACCEPTS_SHUTDOWN)
        WIN32_EXIT_CODE    : 0  (0x0)
        SERVICE_EXIT_CODE  : 0  (0x0)
        CHECKPOINT         : 0x0
        WAIT_HINT          : 0x0
SERVICE_NAME: dnscache
        STATE              : 4  RUNNING
                                (STOPPABLE, NOT_PAUSABLE, IGNORES_SHUTDOWN)
        CHECKPOINT         : 0x0
        WAIT_HINT          : 0x0
SERVICE_NAME: wlansvc
        STATE              : 4  RUNNING
        CHECKPOINT         : 0x0
        WAIT_HINT          : 0x0
Windows IP Configuration
   Host Name . . . . . . . . . . . . : Home-Desktop
   Primary Dns Suffix  . . . . . . . :
Wireless LAN adapter Wi-Fi:
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : RT73 USB Wireless LAN Card
   Physical Address. . . . . . . . . : 00-25-86-EB-55-82
Ethernet adapter Ethernet:
   Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
   Physical Address. . . . . . . . . : 6C-F0-49-00-FE-F5
   Link-local IPv6 Address . . . . . : fe80::b1b3:ff82:2cad:66c2%3(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.1.2(Preferred)
   Lease Obtained. . . . . . . . . . : 17 ڑè¢ي ©, 2014 03:07:43 ê
   Lease Expires . . . . . . . . . . : 20 ڑè¢ي ©, 2014 03:07:43 ê
   Default Gateway . . . . . . . . . : 192.168.1.1
   DHCPv6 IAID . . . . . . . . . . . : 57471049
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1A-25-0F-55-6C-F0-49-00-FE-F5
   DNS Servers . . . . . . . . . . . : 192.168.1.1
   IPv6 Address. . . . . . . . . . . : 2001:0:5ef5:79fb:1c3a:2d3b:3f57:fefd(Preferred)
   Link-local IPv6 Address . . . . . : fe80::1c3a:2d3b:3f57:fefd%4(Preferred)
   Default Gateway . . . . . . . . . : ::
   DHCPv6 IAID . . . . . . . . . . . : 234881024
   NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter isatap.{FBB3E9B6-3BB0-4468-BA67-69230EBE92C4}:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Global Settings:
IPsec:
StrongCRLCheck                        0:Disabled
SAIdleTimeMin                         5min
DefaultExemptions                     NeighborDiscovery,DHCP
IPsecThroughNAT                       Never
AuthzUserGrp                          None
AuthzComputerGrp                      None
AuthzUserGrpTransport                 None
AuthzComputerGrpTransport             None
StatefulFTP                           Enable
StatefulPPTP                          Enable
Main Mode:
KeyLifetime                           480min,0sess
SecMethods                            DHGroup2-AES128-SHA1,DHGroup2-3DES-SHA1
ForceDH                               No
Categories:
BootTimeRuleCategory                  Windows Firewall
FirewallRuleCategory                  Windows Firewall
StealthRuleCategory                   Windows Firewall
ConSecRuleCategory                    Windows Firewall
Ok.
Current WinHTTP proxy settings:
    Direct access (no proxy server).
    AMD Phenom II X4 945
    GA-MA785GT-UD3H
    DDR3 6 GBytes
    Radeon HD 5750
    Bitdefender
