Solved built in "Virtual Drive Mounter" works Fine with VLC dvd player
jimbo45
Hafnarfjörður IS
4,373
Hi all
once you've got an ISO file on Disc you can mount it with a right mouse click on the file.
You can then use any standard software you like to access the DVD for example I'm playing a DVD (Battlestar Galactica 1980) with VLC
(can[SUB]'t find a replacement for W7 snipping tool but old XP application grabber_2k works fine -- file has to be saved as jpg however rather than png)[/SUB]
cheers
    1 X LG 40 inch TV
    2 X 3 TB sata
    5 X 1 TB sata
    0.12 GB/s (120Mb/s)
jimbo45
Hafnarfjörður IS
4,373
    1 X LG 40 inch TV
    2 X 3 TB sata
    5 X 1 TB sata
    0.12 GB/s (120Mb/s)
