Solved BSOD after fresh start
Okay, some news...
  • SFC finished, with no foundings
  • AMD USB filter deleted, all devices uninstalled like you said
  • BIOS downgraded from FEh back to FEg, It seems unstable
  • Realtek LAN driver updated
Windows has serveral problems now:
  • Now just rarely, but BSODs (uploaded minidmp)
  • Restarts without any log (at least no minidmp)
  • Freezes (like W95 days, PC freeze, mouse not moving, even keyboard wont change Capslock/NumLock light), have to hard reset
After one restar, freeze, BSOD or whatever it was, i selected one repair way, and wondows saved log (and in log, and on screen showed bad path file - instead of C:\ where system is, showed G:\)
EDIT: Computer seems stable, when in pressure, so every time that I turn PC on and start Prime95, PC wont crash/restart/BSOD. At least it works pretty much all the time (or if I just turn game on after PC starts)
EDIT2: Computer usually restarts/crashes/BSODs after approx. 10minutes, now with Prime95 its running for over 5hrs! (same as I said when playing some game)
SrtTrail is log from that windows repairing
    Windows 8.1 x64
    FX 6300
    Gigabyte 990XA UD3 rev 3.0
    8GB Dual-channel
    GTX 760
Enter verifier.exe into the search box and open driver verifier choose delete existing settings confirm and reboot.
Monitor your PC for crashes. If that doesn't help, I'd advise you to stop using virtual drives as I have seen cases where they were the causes.
But, it all looks much better now :)
amd_sata.sys Mon Jul 23 20:34:48 2012 (500D9948)
AMD SATA Controller  AHCI 1.2 Device Driver
[URL="http://www.carrona.org/drivers/driver.php?id=amd_sata.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]amd_sata.sys[/COLOR][/B][/URL]
amd_xata.sys Mon Jul 23 20:34:52  2012 (500D994C)
AMD Stor Filter Driver
[URL="http://www.carrona.org/drivers/driver.php?id=amd_xata.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]amd_xata.sys[/COLOR][/B][/URL]
RTKVHD64.sys Tue Oct 30 10:51:36  2012 (508FA328)
Realtek High Definition Audio Function Driver
[URL="http://www.carrona.org/drivers/driver.php?id=RTKVHD64.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]RTKVHD64.sys[/COLOR][/B][/URL]
ElbyCDIO.sys Mon Mar 4 10:21:51  2013 (513467AF)
CDRTools/ElbyCDIO/DVD Region Killer/VirtualCloneDrive (elby  CloneDVD™ 2)/AnyDVD
[URL="http://www.carrona.org/drivers/driver.php?id=ElbyCDIO.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]ElbyCDIO.sys[/COLOR][/B][/URL]
Rt630x64.sys Fri Jun 21 11:29:10  2013 (51C41CE6)
Realtek PCI/PCIe Adapters
[URL="http://www.carrona.org/drivers/driver.php?id=Rt630x64.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]Rt630x64.sys[/COLOR][/B][/URL]
VClone.sys Wed Jul 24 17:02:55  2013 (51EFEC9F)
VirtualCloneCD Driver by Elaborate Bytes AG
[URL="http://www.carrona.org/drivers/driver.php?id=VClone.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]VClone.sys[/COLOR][/B][/URL]
nvhda64v.sys Thu Oct 9 19:02:27  2014 (5436BFA3)
nVidia HDMI Audio Device (nForce chipset driver)
[URL="http://www.carrona.org/drivers/driver.php?id=nvhda64v.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]nvhda64v.sys[/COLOR][/B][/URL]
nvvad64v.sys Thu Nov 20 16:33:54  2014 (546E09E2)
NVIDIA Virtual Audio Driver
[URL="http://www.carrona.org/drivers/driver.php?id=nvvad64v.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]nvvad64v.sys[/COLOR][/B][/URL]
nvlddmkm.sys Fri Mar 13 16:39:56  2015 (550304CC)
nVidia Video drivers
[URL="http://www.carrona.org/drivers/driver.php?id=nvlddmkm.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]nvlddmkm.sys[/COLOR][/B][/URL]
Debug session time: Mon  Apr 13 15:27:57.739 2015 (UTC + 2:00)
Loading Dump File  [D:\SysnativeBSODApps\041315-7625-01.dmp]
Built by:  9600.16452.amd64fre.winblue_gdr.131030-1505
System Uptime: 0 days  0:00:20.735
Probably caused by : fileinfo.sys ( fileinfo!FIStreamGet+51 )
BugCheck 1E, {ffffffffc0000005, fffff800008622f7, 0, ffffffffffffffff}
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#Example"]KMODE_EXCEPTION_NOT_HANDLED  (1e)[/URL]
Bugcheck code 0000001E
Arguments:
Arg1: ffffffffc0000005,  The exception code that was not handled
Arg2: fffff800008622f7, The address  that the exception occurred at
Arg3: 0000000000000000, Parameter 0 of the  exception
Arg4: ffffffffffffffff, Parameter 1 of the exception
BUGCHECK_STR: 0x1E_c0000005_R
PROCESS_NAME: SkyDrive.exe
FAILURE_BUCKET_ID: 0x1E_c0000005_R_VRF_fileinfo!FIStreamGet
--- E O J --- 2015 Apr 13 20:56:11 PM _88-dbug Copyright  2012 Sysnative Forums
    Windows 10 Pro x64
    INTEL Core i7-2700K 3.5GHz
    ASROCK Fatal1ty P67 Main Board
    HyperX Blu 8GB (2 x 4GB) DDR3 1600
    Gigabyte GTX 980 Ti G1 Gaming
    On-board
    Philips Brilliance BDM4065UC
    3840x2160
    SSD: Samsung EVO 250 GB
    Internal HDD: WD Black 1TB
    External: 2x2TB MyBook drives
    1x4TB MyBook
    1x1TB Seagate Freeagent drive
    Corsair GS 700W
    Silverstone Kublai KL04
    Artic Cooling Freezer Pro
    Logitech G710+
    Razer Mamba Elite 2012
    FF 39.0.3, Microsoft Edge, Chrome 44
    Avast 10.0
Verifier turned off. OK, so let's sum up problems that I have (after verifier was turned off)
Before Windows start:
Cannot turn PC on. Stucking on BIOS loading screen, restarting many times. When BIOS loads up, windows have to either check drive (E:\, so 1TB non-system one) for errors, enter system recovery options, ask for restoring from restore point or some other stuff.
So, turning on PC takes 10 minutes with active 'work', without problems bootup takes like 20 secs...
After Windows start:
I have to turn on Prime95 immediately after boot, because otherwise I will get BSOD, total computer freeze or some random restart. If I will be fast enough to start Prime95, I can do whatever I want. Start up game, load some graphics in it, and then I can turn Prime off. But apparently browsing internet isn't enough for PC, so I have to have Prime turned on while browsing...
Some BSODs attached, don't know if they will help anymore....
    Windows 8.1 x64
    FX 6300
    8GB Dual-channel
    GTX 760
What AV/FW are you using? This is not normal behaviour in the slightest. Please try performing a clean boot.
Debug session time: Wed  Apr 15 08:48:24.781 2015 (UTC + 2:00)
Loading Dump File  [D:\SysnativeBSODApps\041515-8500-01.dmp]
System Uptime: 0 days  0:04:39.639
Probably caused by : ntkrnlmp.exe ( nt! ??  ::FNODOBFM::`string'+1b2bf )
BugCheck 1A, {403, fffff6804ec8e2a8,  ac200001242b4867, fff7f6804ec8e2a8}
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#Example"]MEMORY_MANAGEMENT (1a)[/URL]
Bugcheck code 0000001A
Arguments:
Arg1: 0000000000000403, The  subtype of the bugcheck.
Arg2: fffff6804ec8e2a8
Arg3: ac200001242b4867
Arg4: fff7f6804ec8e2a8
BUGCHECK_STR: 0x1a_403
PROCESS_NAME:  autochk.exe
FAILURE_BUCKET_ID: 0x1a_403_VRF_nt!_??_::FNODOBFM::_string_
Debug session time: Wed Apr 15 08:31:40.178 2015 (UTC + 2:00)
Loading  Dump File [D:\SysnativeBSODApps\041515-7875-01.dmp]
System Uptime: 0 days  12:25:37.696
*** WARNING: Unable to verify timestamp for Ntfs.sys
***  ERROR: Module load completed but symbols could not be loaded for Ntfs.sys
Probably caused by : ntkrnlmp.exe ( nt!KiFastFailDispatch+d0 )
BugCheck  139, {3, ffffd0002bbd39e0, ffffd0002bbd3938, 0}
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#Example"]KERNEL_SECURITY_CHECK_FAILURE  (139)[/URL]
Bugcheck code 00000139
Arguments:
Arg1: 0000000000000003,  A LIST_ENTRY has been corrupted (i.e. double remove).
Arg2:  ffffd0002bbd39e0, Address of the trap frame for the exception that caused the  bugcheck
Arg3: ffffd0002bbd3938, Address of the exception record for the  exception that caused the bugcheck
Arg4: 0000000000000000, Reserved
BUGCHECK_STR: 0x139
DEFAULT_BUCKET_ID: LIST_ENTRY_CORRUPT
PROCESS_NAME: System
FAILURE_BUCKET_ID:  0x139_VRF_3_nt!KiFastFailDispatch
--- E O J --- 2015 Apr 16 02:08:30 AM _88-dbug Copyright  2012 Sysnative Forums
    Windows 10 Pro x64
    On-board
    3840x2160
    1x4TB MyBook
    Corsair GS 700W
    Logitech G710+
    Avast 10.0
I am not using any 3rd party AV/FW, because when I was troubleshooting win7 BSODs it was recomended to me to not use one.
    Windows 8.1 x64
    FX 6300
    8GB Dual-channel
    GTX 760
That's right. Have you tried Clean boot?
    Windows 10 Pro x64
    On-board
    3840x2160
    1x4TB MyBook
    Corsair GS 700W
    Logitech G710+
    Avast 10.0
I am not sure how to perform it. Should I enter msconfig and select minimal boot? Or something else?
    Windows 8.1 x64
    FX 6300
    8GB Dual-channel
    GTX 760
    Windows 10 Pro x64
    On-board
    3840x2160
    1x4TB MyBook
    Corsair GS 700W
    Logitech G710+
    Avast 10.0
Sorry, no success :/ Performed clean boot like in description, WIndows got frozen 30 secs after start.. :(
    Windows 8.1 x64
    FX 6300
    8GB Dual-channel
    GTX 760
Scan your HDD for errors with HD Tune.
Post SS of Health and Error Scan tabs (not Quick).
If that comes up empty, please start your system in Safe Mode with Networking and see if it freezes there.
What is your boot device priority in BIOS?
    Windows 10 Pro x64
    On-board
    3840x2160
    1x4TB MyBook
    Corsair GS 700W
    Logitech G710+
    Avast 10.0
Post from my 2nd PC problem thread:
So, thanks for idea! :) I opened pc, checked all cables (nothin under MOBO) and pulled out CPU. After 2mins I detected bended pin (forgot to take a photo, so attachment is just google image with circled pin which bended) After I bended that pin back, it broke. Whole pin :( but, it is no more colapsing with other pins, and it seems like it solved my 2nd problem (http://www.eightforums.com/bsod-crashes-debugging/64051-bsod-after-fresh-start-3.html#post493891), although I am not sure yet. RAM problem continues....
So, bended CPU pin collapsing with the others was the problem probably, PC is running ~2 days without an need to pressure PC with Prime95 to work normally.
Only remaining trouble is that windows forces me to check E:/ on startup, which I always skip, so I think letting it run will solve this too...
Anyway, BIG THANKS to you softwaremaniac, that you helped me to troubleshoot this case, although it solved itself by another way...
Hope, that I wont need to open this thread again ;)
    Windows 8.1 x64
    FX 6300
    8GB Dual-channel
    GTX 760
Great news. Check your HDD with HD Tune.
    Windows 10 Pro x64
    On-board
    3840x2160
    1x4TB MyBook
    Corsair GS 700W
    Logitech G710+
    Avast 10.0
