Blurry text problem has not been fixed in Win 8.1 RTM
I had a similar problem after upgrading to 8.1. Chrome, system dialog boxes, etc looked blurry as if my graphics card was problematic. But a simple operation solved the problem.
You can just follow this link. A "tick" in a box and it's OK for me now. I hope, it works for others, too.
[Fix] Bold, Blurry or Hard to Read Font Problem in Windows 8.1 - AskVG
Atiro, thanks. I found this page on my own and was going to post it. Definitely fixed the issue for me!
    Windows 8.1 Pro 64 bit GA
    i7-4770K Haswell
    ASUS Z87-PRO
    16 GB of Corsair 1866
    GTX 780
    Cooler Master Storm Headphones
    Dell 27 inch U2711 IPS
    2560 by 1440
    Samsung 840 Pro 250GB SSD plus 2 3 TB drives
    Corsair-750
    Corsair White Graphite Series 600T
    Corsair H00i Water
    Corsair K90
    Logitech G9 Laser
    6.3 MBps
    MS
    i7-4770K Haswell
    ASUS Z87-PRO
    GTX 780
    2560 by 1440
    Corsair-750
    Corsair H00i Water
    Corsair K90
    Logitech G9 Laser
    6.3 MBps
    MS
K, I have found the problem and the solution.
Win8.1 released version does NOT LIKE to have the text size changed. This applies to both the desktop and BROWSERS. For instance, going to the Display page and increasing the text size will cause burred text. So will going to a browser and using CNTL+ mouse wheel to enlarge the browser screen. The browser now becomes blurry (I verified this). The FIX is to check the box on the display section called "Let me choose One Scaling Level". That should fix both issues.
BTW, loading in a new graphics driver will RESET the resolution back to the default, "fixing" the problem.
    i7-4770K Haswell
    ASUS Z87-PRO
    GTX 780
    2560 by 1440
    Corsair-750
    Corsair H00i Water
    Corsair K90
    Logitech G9 Laser
    6.3 MBps
    MS
