Blue screen error, need help
Sweetlol
Hello, I've been playing a game, suddenly my laptop got a blue screen "Your PC ran into an error, please restart" and it keeps doing that over and over again, If I try to put in the win disk, it's stucking if I try repair or install. Is there a tool, or anything I can use/do to fix this...please help me out :(
You need to provide us with a bit more info than that please. How long does it take the blue screen to happen? Is it fairly random or does it seem to always happen around the same point. Like 15 or 20 minutes into playing (consistent, would point to a heat issue) or is it random (like one time it happens in 5 minutes and the other it will happen after an hour, would point to a memory issue.)
Or, does it blue screen as it is trying to boot into Windows? if that is the case, it would point to either a memory issue again, or you had some other sort of hardware failure which I would guess would be a video hardware failure.
Please provide us with as much info as possible. Remember, with computer issues - especially ones like this - there is no such thing as too much information.
It's doing it after each time I try to start, after the logo appears, blue screen. Can't get into desktop, and it does that over and over again. I've tested my components on another pc, they worked awesome, each of them...
Seems like it let me install, somehow, waiting about 30 mins betweens steps in installing the new windows, the thing is when i got to partition format, the partition of my windows was clean, no windows was there anymore.
