BF4 extreme lag w/ gtx 750 ti
panda4cash
I have had 60-90 fps on high settings with this game. No idea what I did, but now with the SAME settings ingame and drivers, I get up to 15 fps. I did check for later drivers and checked for background services. I scanned for viruses and yet haven't found an answer. Temperatures are around 30-40 celcius idle for both CPU and GPU. While in game, CPU is 50% used and RAM is 4/12GB used. Temperatures in game never exceeds 65 celcius. What could be the problem?
Specs:
Gigabyte 750 ti not overclocked
FX 6300 3.5GHz not overclocked
12GB RAM
1TB 7200 RPM
Win 8.1 Pro (never had problems since upgraded)
I will also note that other games like GTA or CSGO or Minecraft runs at normal performance.
BF4 is the problem. It is hit and miss at times. They have a patch coming soon, hopefully that fixes things.
That is not a bad cpu. Should OC it to 4GHZ, it will help. BF4 is the problem. Try medium settings in game.
