Asus S56C BSOD: DRIVER_POWER_STATE_FAILURE
garrets
1
My wife has an Asus S56C which is about 6 months old. For the last 4-5 days, it has been blue screening with the error DRIVER_POWER_STATE_FAILURE. I think it is triggered by coming out of a sleep state and then opening Google Chrome. I have tried to isolate the issue to a certain driver but am having difficulty...she hasn't installed any new drivers recently. Windows did do an update on the 10th, but she says it has been happening since before that.
Thanks for the help, I've attached my logs.
    Windows 8 x64
usasma
Mr. Cranky Pants
5,139
All of the memory dumps point at your Intel Rapid Storage Technology (RST) driver - iaStorA.sys
The MSINFO32 report states that this is a K56CA system - not an S56C system
Asus has both systems, could you please verifier which one we're dealing with here?
These instructions are for the S56CA:
- Go here: ASUSTeK Computer Inc. -Support- Drivers and Download S56CA
- Select your OS from the dropdown box
- Scroll down to the "Other" category and expand it by clicking on the + sign next to it.
- Select the first items (Intel Rapid Storage Technology driver) and download/install it.
- Monitor for further BSOD's
CBDisk.sys Wed Jan 13 04:15:47 2010 (4B4D8F43)
CallbackDisk Virtual Storage Driver
http://www.carrona.org/drivers/driver.php?id=CBDisk.sys
atkwmiacpi64.sys Tue Sep 6 21:44:52 2011 (4E66CC94)
ATK WMIACPI Utility
http://www.carrona.org/drivers/driver.php?id=atkwmiacpi64.sys
AiCharger.sys Thu Sep 22 22:04:40 2011 (4E7BE938)
Asus Charger Driver [br] Likely BSOD cause - haven't seen recently (15Jan2013)
http://www.carrona.org/drivers/driver.php?id=AiCharger.sys
Analysis:
[FONT=lucida console]**************************Sun Jul 14 20:14:59.587 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\071413-261765-01.dmp]
Built by: [B]9200[/B].16581.amd64fre.win8_gdr.130410-1505
System Uptime:[B]0 days 0:50:18.405[/B]
Probably caused by :[B]pci.sys[/B]
BugCheck [B]9F, {3, fffffa80043a5060, fffff801cde967f0, fffffa8009d3b980}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x0000009F"]DRIVER_POWER_STATE_FAILURE (9f)[/URL]
Arguments:
Arg2: fffffa80043a5060, Physical Device Object of the stack
Arg3: fffff801cde967f0, nt!TRIAGE_9F_POWER on Win7, otherwise the Functional Device Object of the stack
Arg4: fffffa8009d3b980, The blocked IRP
BUGCHECK_STR:  0x9F
PROCESS_NAME:  System
FAILURE_BUCKET_ID: [B]0x9F_3_iaStorA_IMAGE_pci.sys[/B]
CPUID:        "Intel(R) Core(TM) i3-3217U CPU @ 1.80GHz"
MaxSpeed:     1800
CurrentSpeed: [B]1796[/B]
  BIOS Version                  K56CA.206
  BIOS Release Date             08/21/2012
  Manufacturer                  ASUSTeK COMPUTER INC.
  Product Name                  K56CA
**************************Sun Jul 14 02:45:17.003 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\071313-259406-01.dmp]
System Uptime:[B]1 days 0:40:46.835[/B]
BugCheck [B]9F, {3, fffffa80043a4060, fffff801c11abb40, fffffa8007e87bd0}[/B]
Arguments:
Arg2: fffffa80043a4060, Physical Device Object of the stack
Arg3: fffff801c11abb40, nt!TRIAGE_9F_POWER on Win7, otherwise the Functional Device Object of the stack
Arg4: fffffa8007e87bd0, The blocked IRP
BUGCHECK_STR:  0x9F
PROCESS_NAME:  WmiPrvSE.exe
MaxSpeed:     1800
  Product Name                  K56CA
**************************Sat Jul 13 01:59:30.638 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\071213-259468-01.dmp]
System Uptime:[B]1 days 10:40:53.457[/B]
*** ERROR: Module load completed but symbols could not be loaded for partmgr.sys
*** WARNING: Unable to verify timestamp for iaStorA.sys
*** ERROR: Module load completed but symbols could not be loaded for iaStorA.sys
Probably caused by :[B]iaStorA.sys[/B]
BugCheck [B]9F, {3, fffffa80044ad720, fffff80275c367f0, fffffa80043d3330}[/B]
Arguments:
Arg2: fffffa80044ad720, Physical Device Object of the stack
Arg3: fffff80275c367f0, nt!TRIAGE_9F_POWER on Win7, otherwise the Functional Device Object of the stack
Arg4: fffffa80043d3330, The blocked IRP
BUGCHECK_STR:  0x9F
FAILURE_BUCKET_ID: [B]0x9F_3_POWER_DOWN_IMAGE_iaStorA.sys[/B]
MaxSpeed:     1800
  Product Name                  K56CA
**************************Thu Jul 11 15:13:40.643 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\071113-273578-01.dmp]
System Uptime:[B]0 days 12:52:52.469[/B]
BugCheck [B]9F, {3, fffffa80043a2060, fffff88002f017f0, fffffa8004029760}[/B]
Arguments:
Arg2: fffffa80043a2060, Physical Device Object of the stack
Arg3: fffff88002f017f0, nt!TRIAGE_9F_POWER on Win7, otherwise the Functional Device Object of the stack
Arg4: fffffa8004029760, The blocked IRP
BUGCHECK_STR:  0x9F
MaxSpeed:     1800
  Product Name                  K56CA
[/FONT]
3rd Party Drivers:
[COLOR=RED][B]atkwmiacpi64.sys            Tue Sep  6 21:44:52 2011 (4E66CC94)[/B][/COLOR]
[COLOR=RED][B]AiCharger.sys               Thu Sep 22 22:04:40 2011 (4E7BE938)[/B][/COLOR]
excsd.sys                   Fri Mar 30 15:52:41 2012 (4F760F09)
excfs.sys                   Fri Mar 30 15:53:05 2012 (4F760F21)
GEARAspiWDM.sys             Thu May  3 15:56:17 2012 (4FA2E2E1)
AsHIDSwitch64.sys           Wed May 30 22:38:32 2012 (4FC6D9A8)
RtsBaStor.sys               Wed Jun 13 06:09:02 2012 (4FD866BE)
IntcDAud.sys                Tue Jun 19 10:40:51 2012 (4FE08F73)
btath_bus.sys               Thu Jun 21 01:22:17 2012 (4FE2AF89)
btath_lwflt.sys             Thu Jun 21 01:22:36 2012 (4FE2AF9C)
btath_avdt.sys              Thu Jun 21 01:22:40 2012 (4FE2AFA0)
btath_hcrp.sys              Thu Jun 21 01:23:29 2012 (4FE2AFD1)
btath_a2dp.sys              Thu Jun 21 01:23:44 2012 (4FE2AFE0)
HECIx64.sys                 Mon Jul  2 18:14:58 2012 (4FF21D62)
iaStorA.sys                 Mon Jul  9 16:42:33 2012 (4FFB4239)
dump_iaStorA.sys            Mon Jul  9 16:42:33 2012 (4FFB4239)
DptfManager.sys             Fri Jul 13 19:46:44 2012 (5000B364)
DptfDevDram.sys             Fri Jul 13 19:47:22 2012 (5000B38A)
DptfDevGen.sys              Fri Jul 13 19:47:46 2012 (5000B3A2)
DptfDevFan.sys              Fri Jul 13 19:48:07 2012 (5000B3B7)
DptfDevPch.sys              Fri Jul 13 19:48:46 2012 (5000B3DE)
DptfDevProc.sys             Fri Jul 13 19:49:52 2012 (5000B420)
Rt630x64.sys                Mon Jul 30 12:03:12 2012 (5016B040)
igdkmd64.sys                Tue Jul 31 18:05:35 2012 (501856AF)
kbfiltr.sys                 Wed Aug  1 23:22:22 2012 (5019F26E)
btath_flt.sys               Fri Aug  3 07:09:44 2012 (501BB178)
RTKVHD64.sys                Tue Aug  7 06:49:39 2012 (5020F2C3)
athw8x.sys                  Thu Aug 16 03:01:18 2012 (502C9ABE)
btfilter.sys                Tue Aug 21 23:16:32 2012 (50344F10)
btath_rcp.sys               Fri Aug 24 11:27:40 2012 (50379D6C)
AsusTP.sys                  Mon Oct 29 14:23:54 2012 (508EC9BA)
MDPMGRNT.SYS                Wed Nov 28 16:07:02 2012 (50B67CF6)
MDFSYSNT.sys                Thu Jan 24 15:08:51 2013 (510194D3)
[COLOR=RED][B]CBDisk.sys                  Wed Jan 13 04:15:47 2010 (4B4D8F43)[/B][/COLOR]
[/FONT]
http://www.carrona.org/drivers/driver.php?id=excsd.sys
http://www.carrona.org/drivers/driver.php?id=excfs.sys
http://www.carrona.org/drivers/driver.php?id=GEARAspiWDM.sys
AsHIDSwitch64.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=RtsBaStor.sys
http://www.carrona.org/drivers/driver.php?id=IntcDAud.sys
http://www.carrona.org/drivers/driver.php?id=btath_bus.sys
http://www.carrona.org/drivers/driver.php?id=btath_lwflt.sys
http://www.carrona.org/drivers/driver.php?id=btath_avdt.sys
http://www.carrona.org/drivers/driver.php?id=btath_hcrp.sys
http://www.carrona.org/drivers/driver.php?id=btath_a2dp.sys
DptfManager.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
DptfDevDram.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
DptfDevGen.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
DptfDevFan.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
DptfDevPch.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
DptfDevProc.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=igdkmd64.sys
http://www.carrona.org/drivers/driver.php?id=kbfiltr.sys
http://www.carrona.org/drivers/driver.php?id=btath_flt.sys
http://www.carrona.org/drivers/driver.php?id=athw8x.sys
http://www.carrona.org/drivers/driver.php?id=btfilter.sys
http://www.carrona.org/drivers/driver.php?id=btath_rcp.sys
AsusTP.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=MDPMGRNT.SYS
http://www.carrona.org/drivers/driver.php?id=MDFSYSNT.sys
    Win8.1Pro - Finally!!!
    Samsung/NP780
    upgraded to 12 gB from 8 gB
    800x600
    no Mouse - Trackball!!!!
