Arrow Keys Problem While Typing
RitualJman
Hey there,
I have a Logitech G510 keyboard, I never had any problems until i upgraded to windows 8. If i am typing and try and use the arrow keys to move around with in my text it will just put 3's and w's. I am unsure of what is causing this or what I would really call this problem. If anyone knows how to fix this problem that would be great thank.
    Windows 8.1 Pro 64-Bit
    Custom Built
    AMD BullDozer FX-9590 @4.7GHz
    Asus SaberTooth 990FX R.2
    16GB G.Skill DDR3
    EVGA GeForce GTX 980 K|NGP|N ACX 2.0 x2
    Realtek High Definition Audio
    ViewSonic vx2025wm Acer P191W
    1680X1050 1440X900
    Crucial MX100 512GB SSD
    Seagate 2TB
    WD 2TB USB 3.0 External
    EVGA SuperNova 1200W
    NZXT Phantom 410
    CoolerMaster Siedon 240M
    Logitech G510 Gaming Keyboard
    Razr Abyssus Gaming Mouse
    Realtek Intergrated Gigabyte
    Avast
    Internal USB 3.0 54 In 1 memory card reader, Wired Xbox 360 controller, Wired Guitar Hero Guitar, Logitech Wingman
Der Snoober
Have you checked the keyboardsettings?
You should find the options here ==> Configuration Screen/ Clock, language and country/ Language
Then chose for Options and check the keyboardlayout. A normal keyboard should be "US International" or "US".
You can also try to download the newest drivers from Logitech. Perhaps the old drivers are confusing Windows 8.
Good luck!
    Windows 8.1 Pro x64 Media Center Edition
    Custom Made
    Intel Core i5 750
    6 GB
    AMD HD 7750
    Iiyama ProLite B2481HS-B1
    1x 120 GB SSD Samsung 830;
    1x 1.5 TB HDD Seagate;
    1x 2 TB HDD Western Digital;
    1x 3 TB HDD Seagate
    1x 80 GB SSD Vertex 2
    Corsair CX 600
    Corsair Carbide 300R with Side Window
    Intel RTS2011 LC
    DasKeyboard (blue switches)
    Wacom Baboo Tablet Pen & Touch
    50 Mbit FullDuplex Fiberglass
    IE11
    I also own the following Microsoft devices:
    * Surface Pro 2 128 GB
    * Windows Phone HTC 8X
RitualJman
I'll try it and i'll let you know what I find.
    Custom Built
    16GB G.Skill DDR3
    1680X1050 1440X900
    Seagate 2TB
    NZXT Phantom 410
    Avast
RitualJman
Good luck!
I've tried what you said to try, I've downloaded the newest version of the windows 8 drivers from Logitech's website and checked to make sure that all my settings are set correctly and they are according to what you have said. And it's still doing it, although now its just when your doing a Google search or something along the lines of that.
Thanks
RitualJman
    Custom Built
    16GB G.Skill DDR3
    1680X1050 1440X900
    Seagate 2TB
    NZXT Phantom 410
    Avast
Der Snoober
That's wierd and must be very annoying for you! Let's be hopefull, there is some progress so I see. You might want to consider connecting the keyboard to another computer. Prefferebly one with Windows 8 on in. Just try and see if on that computer you also have the wierd key output.
If you have it on multiple computers it just might be hardware related. If it's working alright you know fore sure it's software related on your own machine.
Emailing Logitech is also an option ofcourse.
    Custom Made
    Intel Core i5 750
    6 GB
    AMD HD 7750
    1x 3 TB HDD Seagate
    Corsair CX 600
    Intel RTS2011 LC
    IE11
RitualJman
I'll try the keyboard on my Laptop that also has Windows 8 Pro 64-bit on it and if its doesn't do it or does do it on my laptop then i'll get a hold of Logitech and let you know what comes of it.
Thanks
RitualJman
    Custom Built
    16GB G.Skill DDR3
    1680X1050 1440X900
    Seagate 2TB
    NZXT Phantom 410
    Avast
